Touch up paint or a touch up stick
Sage
Sagebrush
Rockies
2024 Maverick
Anyone know if there is a touch up paint I could get for a small scratch on my truck?
Zed79
Zed
UP
22 XL AWD
yep you can get it from your parts guy or online would need your ext paint code off the door sticker. or a dealer can look it up with your vin
Sage
Sagebrush
Rockies
2024 Maverick
Thank you very much!!!!
FamousAmos
GAB
Maryland
2022 Maverick Hybrid XL
Also, there are aftermarket brands that match. At least that is true of my silver color. Good luck.
HoiToid
Use your Points and get MotorCraft touchup paint from dealer to make sure it is correct match ( it has paint in one end and clearcoat sealer in other end of container). Allow first coat to dry for 48 hours, , if it needs more than one coat, let 2nd coat dry at least 48 hours. I put clearcoat on per label directions and paint wasn't cured ~~~ clearcoat removed paint so i had to start all over.
Not worth saving a couple of bucks on off-brands that may or may not match exactly.
Redline
Upstate, NY
The Duplicolor stick looks like an easy DIY fix for my door. Thanks for the tip :like:
Billy2mav
William
Abington
I have a shadow black maverick and walmart has touch up paint that matches very well.
Sage
Sagebrush
Rockies
2024 Maverick
Thank You all!!
