Touch screen is blank and won't turn on after restarting
Ferroplasm
M
Subaru Outback Onyx XT
My touchscreen won't display the radio controls at all. If I turn off and restart the truck then the Ford logo will display, disappear, and the screen remains blank. The volume knob and power button work, but that's it. Anyone eelse have this issue?
jeffrol48197
Jeff
2007 Explorer, 2009 Focus, 2019 Explorer
There is a button on the far right of the radio controls that can make it a blank/dark screen - did you try that button?
OleFordGuy
Might try resetting it by pressing/holding down the power button + skip forward buttons for like 15 seconds then release
RonFLA
Ron
O-Town
The radio is in a boot loop. Try exiting the truck and let it sit for an hour and then try again. Maybe consider updating the firmware to the latest version.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hello! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this screen concern. Thanks!
jsus
2022 Ford Escape Hybrid AWD
I'll give that a shot. Is that the command for a soft reset?
Hard reset/reboot, force reboot, call it what you want. Basically, it forces the computer to reboot and is supposed to clear some caches in the process that should keep it from acting up again. It doesn't clear any of your settings/preferences, it doesn't delete paired devices or anything like that.
In other words, the suggestion is to try turning it off and back on again. ;) It's always a good place to start when the system isn't working properly.
Note that the vehicle must be in Accessory or Run in order to complete the procedure. Otherwise it just turns off. Technically you should be able to then turn it back on, but...
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
Had identical symptom. Would crank, but once put in gear screen went blank, turn off and back on and screen went blank. Slightly corroded cable, but Dealer had to remove dash area behind steering wheel to clean off cable.
Maverick drove fine. I was so used to looking at the display and felt weird driving with no display and speedometer.
Metro12
Ohio
2023 Maverick XLT Hybrid
Had the same thing this morning. Reboot/reset procedure seems to have fixed it
NJBob
New Jersey
IL
I know this is an old post but where is this button exactly? This happened to me but could not find the button you are referring too.
NJBob
New Jersey
Damn, Thanks After I posted this I went to the car and found it right away. When the screen went blank I could not find it. It was staring me in the face. I am losing it I think.
Timothyd
I have that same issue! Did you get a fix? That button had no effect.
Thanks,, Tim
Dmthomp32
Doug
Charlotte
2023 Ford Maverick
Reset of the display worked for me when this happened. Hasn’t happened since thankfully
