Torque Pro Android Auto plug-in released!
Gullzway
Gullzway
OK
1968 Ford Mustang Fastback
I really doubt I'd use this much but I can't help but be a little curious. does it need some kind of obd2 interface?
Yes. I use this cheap bluetooth one.
Panlong OBD2 Scanner Bluetooth OBDII Diagnostic Tool Car Code Reader Turn Off Check Engine Light Support Android Torque App https://a.co/d/cUFvE9N
Killerrudy
B rian
Ohio
2023 Maverick
I couldn't get it past this point. It never connected to the ECU. I did make changes to the displayed PIDs and gauge labels after this picture was taken and those did update. Admittedly, I didn't have more than a few minutes to mess with it.
What did you use to get torque on the AA list?
surfstar
2023 XL Hybrid
No battery drain issues with these? Does the OBDII port turn off after a while or stay energized?
jewc75
It turns off. I leave my MXS adapter in the truck.
palmtreefrb
Rick
F150 FX2, Maverick Lariat Hybrid
Found this by accident. I haven't messed with it much yet, but it works. Unofficial plugin.
Native AA plugin when you install using KingInstaller. No need to try and get Screen2Auto mirroring working. This frees up your phone so it can be used like other AA apps work.
https://github.com/agronick/aa-torque
What is the PID for tire pressure? I cannot find it in the list. Do you mind exporting your aa-torque dashboard and sending it to me to import?
TopGun22
TopGun
Ontario
SONATA GL Sport
Did you find tire pressure?
GPSMan
Many
Here's my exported PID from torque.
Remove the .txt from the end and import to Torque.
Will you monitor HVB inlet temperature consistently for a few days please?
Specifically, look first thing, after sitting all night, and before driving. See if it consistently matches ambient within 1 or 2 degrees. Or if it is always too high.
It's ALWAYS higher than ambient on a scangaugeIII.
TIA
801Maverick801
Utah
Subaru Forester
If you have a DTC occur, will Torque let you know? And provide the code?
Gullzway
Gullzway
OK
Yes when you scan for codes. This is from our 2008 Mini Cooper when you don't keep the oil topped off.
Ford Maverick Torque Pro Android Auto plug-in released! Screenshot_2023-07-03-15-08-26-68_b9c66f921be6b9ee18febc2ed6906538
Akunz
Adam
So ILL
Maverick,Passat TDI, Pacifica
Thanks for starting this thread! I was able to add tire pressure after importing your PID.
Ford Maverick Torque Pro Android Auto plug-in released! screendump - 2023-11-21-20_41_12
TopGun22
TopGun
Ontario
SONATA GL Sport
Anyone have success importing ?
I have tried the newest and previous version of AA torque and both crash the app while importing.
Gullzway
Gullzway
OK
Import the PIDs in the Torque app.
