- First Name
- Marty
- Jan 3, 2025
- North Carolina
- 2026 Ford Maverick Tremor
- Engine
- 2.0L EcoBoost
A harder tire bounces up over a bump then comes back down, this is like tapping the brakes to a small degree, hence an mpg drop. It skids ever so slightly and it has to regain its traction.Yes
I did, put it up to 39 psi and it made it worse. Now back to 34 and back to 37-38 mpg
Resistance is futile Jean-Luc. :’P
A properly inflated tire deforms over the bump and maintains more road contact,
Somewhat, thousands of tiny bumps add up.
LESS impact on rebound, les bounce, less rolling resistance.
Ever been on a true washboard road ?
Car slows down and slightly changes direction needing input from the driver.
That’s a perfect example of what I’ve found to be true.
On glass smooth asphalt like the test track where they rate highway mpg, super smooth and near max tire pressure gives the best mpg for that window sticker.
I hardly ever find roads that smooth,
My best mpg is always at the pressure that’s on the door jam.
35 psi for my stock 225/60R18 primacy’s
And to keep even tread wear likely
34 psi when I put on 235/60R18 shoes.
My truck Carrie’s nothing but me
95% of the time.
The other 5%, a 400-500 pound load at most.
