Taillight won't stay seated in place
Mdmac
Kansas
2023 Maverick XLT
Hello, has anyone had issues with the Taillights not staying seated in the White and Black Plugs in the bedside? My driver's side Taillight keeps popping out of the plugs and it is causing a gad next to the bed ? I've tried several times to reposition it and no luck. Any help would be appreciated 👍
Hot Runr Guy
West Chicago, IL
Blue_Max
Orlando, FL
LOL
sorry I meant a gap between the light and bedside
Ah! I figured it was a typo, but couldn't figure out what for. And it is a word, but the definitions didn't seem to fit.
Mdmac
Mdmac
Kansas
2023 Maverick XLT
Got it
rclee
Rob
Dayton Ohio
I fixed mine using rubber garden hose washers/gaskets as a spacer between the light assembly and the body where the bolts go in. I used 3m doublesided tape to hold the gaskets to the body. Then only tighten them a little beyond finger tight. If you crank the screws it will cause it to distort and pop the assembly out at the leading edge.
Good luck
DS_Ohio
SW Ohio
2024 Ford Maverick XL Hybrid
you can also add a little 3/8" wide 3M tape to the light assembly where it contacts the flange and create a camming effect for the (2) screws in the tailgate opening. i did, and did not overtighten. hasn't popped back out since (about 18 months)
i haven't replaced the fender retainers yet, but the next time an assembly pops out, i will take that step
BK007
BK007
OH
I will check mine. I had no idea this was an issue. Is it a widespread problem on our Mavs?
cclark
Curtis
Virginia
2020 Escape, 2023 Maverick XLT, CG, Eco, 4K
Yes, going back to beginning productions. There's a TSB on them. You can search "taillights popping out" and enjoy the responses.
Blu
2023 XL Hybrid
Take it to the dealer if still under 36K. Had my done for the driver's side replaced under warranty. Parts + labor was $350+ on the invoice.
JTBII
Indiana
2024 Ford Maverick XLT
I had mine replaced under warranty on a TSB. I have a 2024 XLT Eco. Mine started popping out at 10,000 miles. I have 31,000 miles now and no pop outs so far after repairs.
JTBII
Mdmac
Mdmac
Kansas
2023 Maverick XLT
Well thank you I will look into that. Appreciate it
