Taillight assembly keeps popping off
Greendesert
Rits
Pittsburgh
Elantra GT '14, 2022 CRV Hybrid, 2025 Maverick Hybrid Lariat
I opened it up to put lasfit led bulbs. Now, it keeps popping as shown in the picture.
I understand it is held on 2 bolts and if you tighten the bolt too much, it is going to pull up from the back side.
On one side, I could barely tight the bolts to keep it from popping.
Anybody else had this issue?
Ford Maverick Taillight assembly keeps popping off PXL_20240416_212843451
Ford Maverick Taillight assembly keeps popping off PXL_20240416_213011046
Ford Maverick Taillight assembly keeps popping off PXL_20240416_212851247
CurtisB
2023 Maverick XLT Hybrid
Easy fix. The two prongs that go into the hole just need adjusting. Also, there are screws on the other side that are supposed to support it. Check to see if they are missing or loose.
LC48
Johnson County Texas
Numerous post in the past, new grommets seems to be the answer in older post
sanpablo
Rich
Long Island, NY
I had this problem when I had to remove the taillights to put in my bed extender brackets. I found that tightening the bolts while pushing the taillights into the bushings worked. Do not over tighten the bolts. There is a sweet spot. Some have said this doesn't work but it did for me.
generalmgr
Wes
Clarion, PA
2023 Maverick XLT EB
Same for me…. Not over tightening is the ticket.
CurtisB
Makes sense because you are putting more pressure on where the bolts are, causing uneven pressure where the slots pop in.
Montana
Some have replaced the grommets, but for me I noticed it was simply just not seating properly and needed a bit of elbow grease to get it in there.
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
When I put my LASTFIT lights in my left side did that. A mechanic at OMEARA FORD, started at the bottom of the light. I put it in that hole inside until he heard a snap and then he pushed the top in , problem fixed.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
