Tailgate lights recommendation?
Cancunbadlands
Cancun
Cancun
B.R.E. (Before Rear-Ended) I ran the extra strip along the bottom edge of my tailgate, others have run it under, along the back edge of the bed. Now mine is along the bottom edge of the tail gate cap, right up, in their face. I had almost 3,000 miles B.R.E., and now have 15,000 A.R.E. for a total of 18,000. Oh, and also along the top edge of the rear window.
https://amazon.com/dp/B07VSHB4Z8
https://amazon.com/dp/B003AT2W54
https://amazon.com/dp/B0BNCNP1D1
I don't do things the easy way, so mine are tapped into the front turn signals and the Center-High-Mount Stop light for redundancy (separate circuits).
The BRE didn't work! The tailgate looks banged up from a collision
Cancunbadlands
Cancun
Cancun
EffNo50
Central California
Thanks.
You'll have to educate me on what C.H.M.S. abbreviates for.
I've not experienced any difficulty from the OCD regarding the pulse bulb on the cab, but then again, we have different year Mavs and that may be a factor, or just a defective bulb. (?)
* I often quote myself - seems reasonable to be able to follow myself.* :ROFLMAO:
Sorry, I was missing a letter: CHMSL (center high-mounted stop light)
My OCD was due to the bulb and the module not flashing in sync with each other.
EffNo50
Central California
The tailgate is the original. It hasn't been replaced yet. It still functions perfectly fine and they want too much money for new and even more for used. Someday I'll find a deal, until then I disguised the dent with the peek-a-boo sticker :)
Tech Tye
Ken
Kentucky
2023 Maverick
I put the 48” OPT 7 on the top of the tailgate. DONT HOOK IT TO THE 4 PIN as it will cause all kinds of issues. Opt 7 made a power adaptor to repower it, it has been discontinued. The curt one looks the same function. I ran some 6 wire cable from the tailgate to the area behind the back seat. You can tap all the wires you need there as the harness that feeds the brake lights is right there. Also the opt 7 is solid aluminum with a silicone filler. I bent mine to fit the curve of the tailgate. Mounted with 3M tape. Use an adhesive promoter when bonding to the plastic trim and it’s stuck . Changed my reverse lights to feniex cannons so there red on brake and flashing white strobe on reverse . Also does amber/white strobe. Changed my 3rd brake light out to feniex wide strobes for brake , strobe function . Added a couple of feniex cannons for the break and area light for night work
Ford Maverick Tailgate lights recommendation? IMG_9122
Ford Maverick Tailgate lights recommendation? IMG_9120
Ford Maverick Tailgate lights recommendation? imag
Dad
I've often wondered why I see members quote a post. Then never follow up with anything.🤷‍♂️
I was responding to his statement that he doesn't follow himself so he cannot see how effective his pulse bulb is for braking. I was making a joke about it. Hopefully, my joke wasn't too corny.
EffNo50
Central California
Well, now that you've explained it...
Ford Maverick Tailgate lights recommendation? 1778895897235-d
  • Haha
Reactions: Dad
