Tailgate light bar-Reverse light question
Hot Runr Guy
West Chicago, IL
For those that are using a powered 4-flat converter (like a Curt # 56477) to power a light bar, is having a non-powered reverse light circuit (direct wired to taillight) a problem, or does a plug & play 5-wire converter need to be created? Not sure how sensitive the OEM reverse light circuit is.
HRG
dennish
Goodyear, AZ
Ford Maverick Hybrid Lariat :-)
I just took power off of the reverse light wire in the curt harness and for the past 2 years have had no issues.
GaryTerry
Indiana
2025 Ford Maverick XLT AWD FX4
what light bar do you have? the one I tried didn't work at all with my truck..
dennish
Goodyear, AZ
I used the curt harness:
https://amzn.to/3XzjLCk
I was lazy 😄 I took a shortcut and tapped into the reverse light circuit using the Curt harness on the driver’s side. Instead of running dedicated power all the way to the battery, I opted to use the existing 12V wiring in the truck bed. Also, living in AZ I just used automotive velcro to mount it to the bumper so I could remove it if I needed the spare. After two years no issues. 🤞
Ford Maverick Tailgate light bar-Reverse light question 2025-03-30_09-27-31
Hot Runr Guy
West Chicago, IL
Not being lazy to me, if I were to install a light bar I would do the very same thing, adding the reverse light feed from the short jumper on the Curt harness, as well as power from the FlexBed.
HRG
