Tailgate light bar concerns / questions
Vomamansr
gary
Long island ny
Looking for help with installing a tailgate light bar has anyone done this and what type did you use my concerns are having access to the spare tire and trouble maybe with the wiring running up to the tailgate if it interferes with the light bar.
I have a 24 lariat
SteveW12TCA
North Ridgeville, OH
I installed a Putco light bar using the Curt wiring harness, running cable to battery under the back seat (hybrid). I attached it with strong magnets I purchased on Amazon. It does cover the spare tire hole but should be "easily" pulled down if I need to access the tire. It has been in place for 1.5 years with no issues. The light bar does sit a bit high so that I could get solid metal contact. Overall, I've been quite happy with this set up.
William Buckman
Buck
Dothan Alabama
24 Lariat Carbonized Grey
Could you please provide a link? Was wiring hookup difficult?
SteveW12TCA
Here are the links you requested. Very straight forward. The Curt wiring harness lets you "get power" from a 4-pin connector so you don't use the Maverick 4-pin connector on the hitch. If you do use the installed Mav 4 pin connector, the truck thinks you've attached a trailer. Hope that makes sense. There may be something out now that is more "plug and play"...not sure since I did mine a couple years ago on my 2023.
https://www.putco.com/product/red-white-blade-led-tailgate-light-bar/
https://www.etrailer.com/Custom-Fit-Vehicle-Wiring/Ford/Maverick/2024/C59DR.html
MAGNETS:
https://www.amazon.com/SALEX-Dashbo...4303&sprefix=salex+magnet,aps,136&sr=8-1&th=1
Hot Runr Guy
West Chicago, IL
Steve, did you tap into a reverse light circuit for the light bar?
HRG
SteveW12TCA
I believe so...but it's been a while. If I remember correctly I took it up to an automotive wiring place nearby and they helped me find the correct wire to tap in to.
Vomamansr
gary
Long island ny
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
Put this under bumper with 1 1/2" alum. Angle.
True Mods 49" LED Tailgate Light Bar + Signal Relay Box [Ford F-150 F-250 F-350 Super-Duty up to 2018] [Sequential Turn Signal] [Tail & Reverse Light] for Ford Pick-Up Trucks with Tow Package & BLIS https://a.co/d/6eovtSD
This one plug and play with no lost of reverse guide lines in the cab screen info center
Ford Maverick Tailgate light bar concerns / questions 20240126_160805
Vomamansr
gary
Long island ny
Thanks
