- First Name
- Lane
- Jul 20, 2023
- Central Wisconsin
- Website
- photos.app.goo.gl
- 2023 Area 51 Hybrid XL, 2006 VW Jetta Smyth UTE
- Engine
- 2.5L Hybrid
Since the prior thread on this topic is closed, here's what I did to address it.
A past truck I owned had rust come through the paint on the bottom of the tailgate and it started to appear about 3 years from when it was new. I'm convinced it's from dirt, wood chips, leaves, grass, and everything else making its way into the tailgate vent holes. It sits in there for years and retains moisture and rusts it from the inside out.
Before I hauled anything in my Maverick, I wanted to reduce the odds that this was going to happen here. It'd be easiest to put some butyl tape right over it, or as others have suggested, 3D print a cover for it but I don't think those are good options as they'd reduce the airflow provided to the inside and make it even more likely to hold moisture.
In the existing tailgate hole, I added a zip tie to the harness which exits the hole to hold it to its plastic fastener better so it wouldn't move around as much as the gate is opened/closed. I cut a piece of fiberglass window screen a bit bigger than the hole, and notched out a spot on one end for wiring clearance.
I masked off the hole, then applied a couple millimeter layer of clear silicone around the perimiter. Embed the screen in the silicone.
I don't know if it will keep everything out, but it will certainly be better than it was. The fiberglass screen isn't the strongest, but I'll be installing a tailgate gap cover shortly to keep the big stuff out of the gap completely. And if I ever need access into the gate through that hole, the screen and silicone can just be peeled off.
