Tail light connectors for TOAD Maverick
DiverUtah
Layton, ut
2023 Maverick Lariat Hybrid Cyber Orange
Just a little info on tail light connectors for TOAD Maverick. I wanted to install Tail Light Isolating Diodes https://a.co/d/a5TvzSn but did not want to cut into my factory wiring so I found some connector pairs on Amazon https://a.co/d/a5TvzSn that plugged in perfectly on my 2023 Maverick Lariat Hybrid (I don't know if this will fit other models)
Ford Maverick Tail light connectors for TOAD Maverick Connectors
Cancunbadlands
Cancun
Cancun
I got a pair in my glovebox from Ford
BlueSpec1
Gene
What was the diode link?
Tony Pandy
Tony
2025 Lariat Hybrid, F53 Chassis Class A Motorhome, Acura TLX, '79 280ZX
Can anyone confirm this will work on the 2025 Lariat ? Seen others on various forums stating that the 2025 Lariat LED rear tail light assembly uses a different harness / connectors tham previous model years. I would prefer to use a plug like these vs cut & Splice or scotch locks etc.
Tony Pandy
Tony
I have the same set of diodes I bought a few months ago from same seller on amazon. They are good quality in build from visual inspection (Have not installed yet). They are a lot less expensive than the various Towing specialty sellers (e-Trailer, Hopkins etc.).
DiverUtah
DiverUtah
Layton, ut
Pop out your tail lights and compare the plugs to the picture. That is what I did.
Kurt
Wyoming
2025 Maverick Hybrid AWD
Has anyone confirmed these connectors work with the 2025? I don’t mind popping out the light and comparing to the picture, but I’d feel a lot better if someone has actually tested them out.
Thanks!
Cancunbadlands
Cancun
Cancun
Kurt
Wyoming
Thanks!
I’ll answer my own question here. NO, THIS CONNECTOR WILL NOT WORK IN THE 2025 MAV. Looks just like it in the pictures, but slightly different shape and won’t plug in.
BlueSpec1
Gene
Wonder if connector is still Molex MX150 type, just different Key Option.
Ford Maverick Tail light connectors for TOAD Maverick 1761771548744-of
2023 was a Molex MX150 2x3
Ford Maverick Tail light connectors for TOAD Maverick 1761771376593-a8
EffNo50
Central California
Are you sure those are for the tail light assemblies? The 2 connectors usually supplied with the trucks is for the 12v FlexBed connectors near the tail gate.
Hot Runr Guy
West Chicago, IL
Cancunbadlands
Cancun
Cancun
You're right, my bad
