I did not. But I have a lariatDid you need to add an antenna for the factory nav to work?
No issues on my lariatPin 8?
My assumption is my audio bugs have to be a result of the harness since they didn’t exist before. Though the Sync3 APIM did have an issue of the occasional audio skip. This is more of a very soft static pop. Almost like a record with a little dust. Two to three times a song.
Unsure if it’s harness, APIM, or software at the moment. Maybe I’ll reset the audio module?
Am using the B&O system on the Lariat which I don’t think would cause an issue?
Feel like harness is my best bet then. This static pop has to come from some sort of electrical connection. Or at least I hope?No issues on my lariat
Did you twist your wires as neededPin 8?
For the splicing in of the other cable that powers the screen?Did you twist your wires as needed
Do you have the wiring diagram? If you look there are a number that should be also shielded I wrapped mine with shield tape Amazon. Like $8.00For the splicing in of the other cable that powers the screen?
Does this apply to a Lariat that was already equipped with Sync3? From RedNeckGarage video he never mentioned having to adjust any other cables besides the harness adapterDo you have the wiring diagram? If you look there are a number that should be also shielded I wrapped mine with shield tape Amazon. Like $8.00
There are others
Sorry I forgot you were updating, ask Bill, he may know since he did updateDoes this apply to a Lariat that was already equipped with Sync3? From RedNeckGarage video he never mentioned having to adjust any other cables besides the harness adapter
It's posted somewhere in this thread . Check towards the middleFeel like harness is my best bet then. This static pop has to come from some sort of electrical connection. Or at least I hope?
You wouldn’t happen to have or be willing to share your as built file would you? Am slightly curious if I just uploaded it to mine if it would narrow down my back up camera issue
Amazing work man! While my harness is definitely the issue when it comes to the visual quality, the vehicle know turns the camera on when put into reverse.It's posted somewhere in this thread . Check towards the middle
