Strut tower brace Steeda
Paulyz
Paul
Forestville, WI
It is NOT a mandatory thing. It is simply a Strut (support) that connects the two Front Suspension towers and helps keeping the body "stiff".
Which means, Less body flexing that occurs overtime.
It was a common thing to add to early Mustangs.. My Brother had a few...
Installing one doesn't hurt... :wink:
Jerry
Yes, I installed a Steeda strut tower brace on my 2007 Mustang & even through my steering was tight, the brace made it tighter, stiffer, no body roll on turns, like driving a go kart. I plan on getting this for my Maverick as well. Does anyone know the torque settings this brace? Is anything in the way when installing it? Thanks.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
I just answered another thread on installing this, a few months ago..
There is a canister, that I had to loosen and reattach with a wire tie...
I also included some photos....
Check out this thread....
https://www.mavericktruckclub.com/f...k-steeda-strut-tower.13939/#convMessage-75242
Jerry
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
Ford Maverick Strut tower brace Steeda Steeda Install (3)
Below is the final installation. I have noted the mods that I had to make it fit with little work...
Ford Maverick Strut tower brace Steeda Steeda Install details
Ford Maverick Strut tower brace Steeda Steeda Install Cansiter Cli
I highlighted the "Clip" and "hole in the bracket" that I had to leave "Loose" for the Strut to fit with minimal rearranging of components... ;)
Jerry
little kenny
little kenny
kenny
wisconsin
2024 ford maverick tremor
The angle is determined by the original bolt location (angle).
You are replacing one of the front strut bolts with a (supplied longer one)..
Jerry
[/QUOT
What is its purpose? Why would you need this?
the purpose is to support and prevent the unibody from twisting going off road. it also help steering and and make the front in seem tighter and have faster response time. it also has aesthetic value.
little kenny
little kenny
kenny
wisconsin
thank you everyone for the helpful information I really appreciate it that I can ask questions and not be treated like I'm stupid cus I don't know about something
Hot Runr Guy
West Chicago, IL
Does the Steeda block access to the brake master cylinder?
HRG
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
HRG
I would have to take a look..
It Does block removal of the battery.. :(
Jerry
HRG
Your EcoBoost could be different.
I own a hybrid. No master cylinder or booster per se, they're electric brakes.
If you are speaking about the brake fluid reservoir. No problem, there is plenty of room with a Hybrid as the picture's show.
Good Luck
Ford Maverick Strut tower brace Steeda 20240904_084112
Ford Maverick Strut tower brace Steeda 20240904_085041
