Spray in bedliner vs tailgate liner kit
  • Thread starter Deleted member 23340
  • Start date
  • Watchers 1
AF Blue
US
NA
DIY - cut mat/outdoor carpet to fit tailgate?
Do you still have Ford Points?
SPRING15 is current 15% off code .. there was a 20% off code a few days ago.
Ford Maverick Spray in bedliner vs tailgate liner kit 1681347670868
Timothyd
Trying to determine whether or not I should buy the tailgate liner kit. Currently I do not have a spray in bed liner. I do have a horse mat that is cut to fit in the bed, but that's it.
When getting a spray in bedliner, does that usually include the tailgate? If it does, would it be cheaper to forego the tailgate spray in and buy the tailgate liner kit instead ($75)?
I have the spray-on, which I like, and that included the tailgate. Get the tailgate kit for now and if you ever get the spray-on you and put the cover over that and keep it pristine.
Guest
That's a possibility.
Guest
Yeah I still have my points. I will check it out. Not sure if I need to buy it if I already have a horse mat. Only improvement would be sidewall protection. We shall see, thanks for the idea
catshreds
Roland
2023 XLT AWD
What does the forum think about BedRug as an alternative to to a SIBL or DIBL?
Maverickent
Kent
Mason City, IA
I agree that it's a costly mod. Other benefits are that it improves the appearance and gives significant sound deadening. You can also get it in any color you want.
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
I got a ford bed mat and a tailgate liner both using ford points. For the sides I use a big piece of tarp from Costco. I don’t do construction and the only things going into the bed are groceries and baby stroller. I was considering a spray in but the cost vs what I use the bed for isn’t worth it to me
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
Same here. Ford bed mat and tailgate liner. The tailgate liner removes the metal plate from tailgate. Kinda chessy. Because of that, doesn't make much sense to spray the tailgate AND have the plastic liner. I'd say either-or. I'm a fan of the painted bed, can always spray later. My door jam says 1500 lbs payload because of the naked bed.
Guest
Same here .. Minus the tarp. I use a horsemat instead of a rug though
Guest
Can you elaborate on why you don't like the bedrug? I was planning on going this route.
Not thick enough to be cushiony, if it gets wet or left in weather, it can easily mildew and stink. Personally don't think they look good. I currently use a black horse mat cut to fit that's an inch and a half thick, pads me well for my knees and anything heavy. Removable if needed.
tom_tucker
mid atlantic (VA)
Ha! This guy's is in Vegas and he wants to avoid moisture in the rug. I agree, that's why I got the rubber Ford bed mat. I also ordered a camper bed top with no carpet liner. I'll be able to hose it all down with no issue.
Regarding the original question, it would be nice to have the tailgate spray lined vs the plastic tailgate protector. So the rest of the bed is still painted besides the tailgate and then drop in the rubber bed mat. That's what I would do if I could start over.
Guest
Maybe you're not aware but it snows and rains a lot in the mountain areas.. so yeah, moisture. Sure it's not as bad as other states, but still happens. Also, car washes are going to soak that carpet every time.
The rubber mat is a better option especially for hosing it down. I would suggest going to tractor supply or somewhere like that instead of Ford, it would be cheaper. Mine was $47.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
With the "thin-ness" of the "eco safe" paint nowadays, I didn't put ANYTHING into the bed before getting it sprayed- any scratches could start the rust process, and I hope Mav serves our family for a long long time.
