- First Name
- Larry
- Sep 7, 2021
- Massachusetts
- 92 Toyota Pickup. 22 IS hybrid Maverick. ‘25 Hybrid RAV4
- Engine
- 2.5L Hybrid
At the risk of repeating myself, over multiple threads…………
It‘s important to Ford to maintain a high MPG rating for its CAFE standards. To do so requires that the Mav run in electric mode as much as possible. Doing so, under the current setup, does not allow enough amperage to help the battery stay properly charged. A larger (better?) battery would only delay the result.
Drive around town, slower speeds, more electrical use, less battery charging, higher MPGs.
Drive on the highway, higher speeds, less electrical use, more battery charging, lower MPGs.
Ford could change the charging algorithm, at the loss of some MPG rating.
Meantime, keeping the state of charge on the low side, only diminishes the life span of the battery.
What gets my goat more, is that it considerably reduces the FordPass connection. Can’t start, lock, unlock, etc through the app, something that Ford likes to brag about.
Change the charging algorithm, lower MPG’s, maintain battery health. Problem goes away.
