So after reading the issues others had with the center channel being too bright and forward, I decided to try something a little different.
I noticed everyone seemed to replace the center speaker with a 4ohm two way. I decided to try a one way/full range speaker instead. I thought the tweeter in a two way might contribute to the problem. There aren't many budget friendly options, so I decided to give this a try,
https://www.amazon.com/DS18-ZXI-354-Speaker-Upgrade-Kevlar/dp/B09GBJYNF4/ref=mp_s_a_1_2?crid=1MAU2XBJLSKMY&keywords=ds18+3.5+speakers&qid=1699310371&sprefix=ds18+3.,aps,180&sr=8-2
Ds18 is not my first choice, I just don't know the brand. But it fit the parameters I was looking for. I added a 4ohm resistor to tone it down to 8ohms like the factory speaker, made a bracket out of plastic and installed it.
I think it sounds very good. I don't find it forward or bright at all. It fits in with the other speakers very well, even in surround mode.
I installed the subwoofer grill also, I'm finally happy. The biggest problem I had throughout this whole thing was chasing down all the rattles. They just ruin the experience. This concludes my upgrade. I hope this helps someone else out there.
it's a reasonable experiment since I don't think anyone has measured or knows the frequency range the audio control module sends to the center.
however we do know that a full range driver struggles above 4 to 5khz. that's why tweeters exist. so if it's playing higher frequency and I suspect it is, a coaxial may perform better.
22Lariat
22Lariat
New Hampshire
2022 Ford Maverick Lariat
ds18 claims the frequency response is 120Hz-20KHz... But if all "full range drivers struggle above 4 to 5khz”, not producing over 4 to 5khz would help achieve my goal. My goal is to reduce the brightness and forward sound others have complained about. Exactly what's produced by a tweeter. If you suspect the ACM is playing higher frequencies and you consider brighter and more forward sound "performing better", then by all means install a two way. IMO that would ruin the sound stage. I considered the fact there are already two tweeters up front. And I presumed B&O didn't add a third tweeter in the center by design. Perhaps because a third tweeter would be too bright and forward?
I'm trying to fix what I considered the short comings of the B&O system, not outright replace it. Simple speaker replacement and a different sub seems to have achieved that goal. I believe I have unlocked its potential. And I am very happy.
I would welcome you to take a listen for yourself if you're ever in the area.
I didn't have time yesterday to look at your link and investigate, but I did now. It's a coaxial. Check the manufacturer page: https://ds18.com/products/elite-3-5-full-range-speakers-with-glass-fiber-cone-120-watts-4-ohm
"The bullet on the ZXI-354 equips the 3.5” woofer with a 1” ferrite Magnet Tweeter, which delivers unmatched clarity and detail in the higher end of the frequency range. "
That's not to prejudge how it sounds. I believe you if you feel it's an upgrade because the stock center speaker is pretty harsh.
22Lariat
22Lariat
New Hampshire
Oh yeah... The invisible kind. Lol. You're right. You win. You're so much smarter than me. Push button/get pellet.
I'm not trying to win anything, I thought we were having a discussion? Maybe I'm taking 'full range speaker' way too literally or I'm just too damn old. :LOL:
To me it's a term that means it's a single driver covering a wider-than-typical frequency range and typically it won't play real low or real high. I think that might be what you were expecting also, but I see a bunch of coaxials when I google it including the brand & model you mentioned.
22Lariat
22Lariat
New Hampshire
No no no... You're right. I should have clearly stated it's a single driver "coaxial" - invisible tweeter style speaker. It's not the type of speaker that has an "actual" tweeter in it. My bad.
Beloff
VA
94Blazer 06Prius 23Maverick
Thank you for your sharing.
B&O system is my biggest disappointment after finally getting my maverick. IMHO, JBL in 2006 Prius sounds better - that's how bad B&O is 😭
txquailguy
Colorado
2023 Maverick Lariat FX4 and Bronco Sport Big Bend
What do you audiophiles think about the Infinity Primus 6.5 component set (PR603CF) to replace the front speakers? Also, do you need to take the door panel off to get to the door speakers?
DTF-Garage
Brad
2000 Focus ZX3 (RWD Swap), 2011 Focus SES
After reading your thread I decided to tackle this as well. The Subwoofer I got had a huge magnet and I definitely had to hack up the bottom of the original sub enclosure, and ended up going through 3 different 6x9 adaptors from Amazon until I found one that actually worked. Definitely doesn't sound amazing, but it's better than the stock B&O sub
Ford Maverick Simple B&O upgrade and sub solution. 20231112_135225
Ford Maverick Simple B&O upgrade and sub solution. 20231112_135158
22Lariat
22Lariat
New Hampshire
Yeah, Is that the scar evl? I considered that sub. If I remember correctly it needs a lot of power to run it, and I wasn't sure the B&O amp would have enough juice to run a 200 rms dual coil sub. Plus, I didn't want to cut the enclosure.
I bet you'd get a lot more out of that if you hooked it up to a mono sub amp. But I guess at that point you might as well scrap the whole B&O enclosure too.
I tried to keep it simple. It added depth while remaining balanced. I love it. But you can't expect miracles.
DTF-Garage
Brad
22Lariat
22Lariat
New Hampshire
Yours looks more cool than mine...😎
22Lariat
22Lariat
New Hampshire
I waited almost a year before upgrading the XL's sound system in steps...not by plan, but by delivery of the components.
The first to arrive were an Infinity Reference four speaker kit that contained REF-6532IX 6.5" 2-way for the front and REF-3432CFX 4x6" 2-way rear. The set was $99 from Amazon. I installed the front using the included adapters plus sound insulation inside the door cavity. I drove it a few days noticing a tremendous improvement on the sound. I probably could have stopped here and enjoyed the sound system...but that's not me.
Next I installed the 4x6" in the rear and they bolted to the factory mounts, shaping the sound with gasket material to fit the cone in the C-pillar trim piece. I changed the sound settings to "all seats" selection. Another overall improvement in sound for me. I did not notice any frequency limitation after changing the sound settings and installing the 75Hz-21kHz 4x6" rear speakers.
Next to arrive was the Puzu PZ-C7 DSP Amp (found it on eBay for about $120, including the plug & play harness). Naturally it had the wrong harness, so I waited until I recieved the right one. The DSP Amp was a super easy install just by removing the harness connector at the ACM and plugging the T-harness in it's place and snaking the DSP Amp leads under the edge of the console and putting the DSP Amp under my drivers seat. Since the DSP Amp I bought was inexpensive and rated at 45W RMS, I didn't expect much improvement, but I was blown away.
I set the 3 bands on the factory ACM to flat and switched back and forth between amp mode and bypass. Again, it was remarkable the difference and that's without messing with any DSP settings. The music seems more alive through the DSP Amp. There is clarity in individual instrument sounds, clear channel separation, and consistent volumes.
I've said before I like the bright sounds of surfer music and Jimmy Buffet's attempt at Reggae. Those of you that have listened to Jan & Dean probably have experienced the duo singing and a muddled mess of background music without definition, which makes it hard to listen to, especially on low quality systems. Yesterday, a Jan and Dean song came on and the background guitars were clear, bright, and individual notes could be definitively heard with a solid plunk. Drums too. Reminds me of my old Kenwood system with Bose 901s in the front and 601s in the rear, probably due to the Maverick Cab acoustic properties. Listening to music like Acoustic Alchemy and Buggs Henderson is a real pleasure.
Finally, I installed and connected the power and DSP subwoofer output to a Rockville RW68CA subwoofer. I could have done without the sub and been fine with in my ignorance; however, after listening to it even at moderate settings, it fills out the lows very nicely. Although it has the capability to hammer and thump far more than I actually want to listen to. So overall, I now have an audio system that is far more capable of producing nice rich and full sound across the full spectrum of my hearing. The sub gives me the ability to listen to frequencies from 53Hz down to 20Hz as well as fill out the bass up to 100Hz.
Another benefit to adding the subwoofer, it gives the rear speakers a more prominent role. The frequency response of the 4" x 6" rear speakers is 75Hz-21kHz and sound great with the addition of the subwoofer to fill in the bass down to 20Hz.
So, overall, the system sounds better with the moderate subwoofer adjustments to fill in the bass. It was worth the nominal $115.00 cost (Subwoofer plus wiring kit).
So, the installation in stages worked for me and I enjoy the sound system tremendously. I've not noticed anything but clear sounds without clipping which happened regularly with the stock sound. Of course, I've not tried to overload any of the speakers. I know what I installed is not for everyone, but it fits with my preferences and compared to the original stock XL sound system it sounds amazing.
Everyone's cost effective thresh-hold is different. My installation was cost effective for me since it was what I could afford. :cool:
I bet that sounds really good. And reasonably cost effective too.
"I probably could have stopped here and enjoyed the sound system...but that's not me."
I know what you mean. I have to restrain myself. Mine sounds good and I'm happy, but that DSP and custom sub is still calling me. I should act my age and preserve my wallet, and I would like to avoid hearing aids in the not too distant future. Lol
HushCarAudio
Gold Sponsor
Bruce
Aubrey TX
You also could have used two of these https://www.skaraudio.com/products/...ch-400-watt-loaded-vented-subwoofer-enclosure
along with an Audio Control acm-2.300 for a lot more bass output. I believe these would fit in the storage compartments. I've yet to test fit them but think they will fit. Does anyone have the actual measurements for the compartments yet? My truck isn't here yet so I can't verify anything.
todd92
You're derailing the thread, as the OP's intent was to make simple and cost effective improvements which for sure didn't include a sub enclosure and amp under the seats. There are plenty of other threads that discuss that option. Ground-Shaker makes custom underseat enclosures that can mount 8" or 10" subs.
