- First Name
- Hawley
- Jul 16, 2021
- Austin, TX
- Honda Insight, E350, Toyota Sequoia
- Engine
- 2.5L Hybrid
The Administrators offered some commercially available ideas and prices for customizing our precious Mavericks when we get them. But...,some were turned off with the idea of the stick-ons at the price point offered. There are alternatives if you just want something flat, and these and be infinitely customizable
There are the pattern cutters that range from small home machines to larger machines that you give the owners a pattern and it gets laser cut. That pattern can then be used as a paint template or a direct stick-on
Hobby machines (Cricut & Brother scan n' cut hobby machines) limit is size!
Then there is the actual paint. Most people know about "dip Your Car" products. Fewer know about Rust-Oleum. Rust-Oleum has a product called "Primer Peeler" Primer Peeler comes in aerosol cans and you can tape your area off spray paint it then use ANY spray Rust-Oleum product to create the effect you wish. like
1. filling in the embossed letters on the rear of your Maverick
2. create your own protective barrier on the bottom of your car panels(smooth or rough texture)
3. create reflective strips or patterns so you r truck is more visible at night.
The possibilities are endless............as long as you don't get tacky and embarrass the other Maverick Truck owners!!!
The neat thing is that you can peel it off when you get tired of it. I am going to try it out with some Duplicolor paint and other paints. If they make colors to match the Maverick colors protecting the bottom panels would be an aesthetic no-brainer! (Touchup zone sells a match for cactus gray (my Maverick color)for $46.00)
