Status
Not open for further replies.
RonaldRampage
Ron
Massachusetts
2024 ford maverick
Just dropped my 2024 xl awd off to get the secondary cat deleted. This is the first of many upgrades. Fingers crossed it gives it some sort of sound.
First impressions:
Just got it back. Very slight change in sound,especially from inside. The engine is still louder than the engine. What I did notice as soon as I drove it was a way better throttle response and less lag. I'm satisfied with the results of this $150 upgrade. I will post the sound clip later when my friend gets out of work.
Secondary cat delete and cat that was removed.
Ford Maverick Secondary cat / resonator delete - removed 20240906_111248
Ford Maverick Secondary cat / resonator delete - removed 20240906_111218
Ford Maverick Secondary cat / resonator delete - removed 20240906_111203
RonaldRampage
RonaldRampage
Ron
Massachusetts
2024 ford maverick
Interested to hear the sound clip.
Just got it back. Very slight change in sound,especially from inside. The engine is still louder than the exhaust. What I did notice as soon as I drove it was better throttle response and less lag. I'm satisfied with the results of this $150 upgrade. I will post the sound clip later when my friend gets out of work.
ShadowBlack XL440
Robert
Northern Ohio
Do you have any vehicle or emission inspections in your State ore county? I would not get away with a modification like this in my area.
RonaldRampage
RonaldRampage
Ron
Massachusetts
2024 ford maverick
I'm in Massachusetts it's very strick here. If it set off a check engine I wouldn't pass but this cat doesn't have sensors attacked so it's all good.....hopefully
ShadowBlack XL440
Robert
Northern Ohio
Same here in Ohio in an E-Check county, but they do a visual check and a missing cat would be an issue even without a CEL.
Rivers90
Ben
XLT Tremor, Miata
The turbo cuts most of the sound of the engine, some turbo engines don't even come with a muffler from the factory like the fiat 124 spider abarth.
ShadowBlack XL440
Robert
Northern Ohio
That makes a lot of sense. My 1st gen Dodge with a Cummins 12V has no muffler so the turbo must quiet it down too.
Tom 71 Maverick 24
Northeast Ohio
I need to get up under my Mav and see what's what there - i didn't even know that there was a "secondary" cat.
Of course, removing it would alert the e-check gendarmes that something was amiss. One could always do what I did to my 78 Pinto - drill through it with a large drill bit to allow more flow. (I was quite young then).
The Cyber Orange Guy.
Devu
Caribean
Maverick cyber orange
Ok, here come the warranty and polution police.
Don't you get on trouble with the dealer or could void the warranty ?
In a regular inspection for emition would get on trouble or not ? Where I'm they check in the rear exaust.
Not trying to create trouble or animosity. Just realy curious about it.
zach57x
FL
2022 Maverick XLT
How would they know thats supposed to be a cat in the first place? There's still the primary cat further upstream
Status
