Rumble update.
ET bagel
Monmouth and Ocean county
Tacoma
My Maverick is misidentified here. It is a 2024 gas only. Not a hybrid. I have a rumble when I am at 1,000 to 1,500 RPM and going 40 MPH. Not accelerating. just cruising.
dealer says it is normal. It is the turbocharger.
I am not convinced. This reminds me of my standard shift car when I was in too high a gear for the low speed I was traveling.
Nothing to do with tires or wheel balance.
any Ideas?
Tbone289
That's exactly what it is. It's "lugging" in too high a gear (IMO) for the sake of better efficiency.
You can change from Hybrid to Ecoboost in your account details.
SuperK401
Kent
S. Ind
89 f-150 custom 03 f-250 super duty fx4
Drive it in tow/hall at those speeds.
ET bagel
Tacoma
So I should not worry? i don’t have to dump it before something bad happens? It is annoying .
Tbone289
There's nothing really to worry about. Your transmission isn't shitty, it's just programmed for efficiency, as already mentioned.
Mox4615
Jeremy
NC
2024 Lariat
I think every EB has this issue. Some say putting 93 octane in will help but I tried that and it didn’t make a difference really. As mentioned you can try driving in tow/haul if you think you’ll be doing a lot of 30-40mph driving, can always change back to normal on the highway.
Tbone289
That's what I do. In situations where the lugging becomes an annoyance, I switch to tow/haul. It's either that for frequently having to dip into the throttle to coax it to shift down.
710-oil-614
Cal
2025 Hybrid AWD Lariat
93 makes a big difference in the 2.0 drive ability
Fishin4ladyz
J
WI
2023 Ram 1500, 2024 Maverick
Mine lugs when it's colder out, truck definitely vibrates quite a bit and drones. There was a TSB posted on here I do believe. I don't have the thread ATM.
Brianx
Pennsylvania
'24 Eco Boost XL Cactus Gray, tow bar, Co-Pilot
I just 🪿 the throttle antad to downshift. hopefully it starts learning my preference.
CajunMick
Heman
Houston, Texas
2023 XLT Maverick
May not be related, but long ago, auto mfrs used 4 cyl engines that suffered 4 cyl “rumble“ due to odd sequences of pistons and firing order. Some have added a counter balance shaft to counter the effect of pistons/crankshaft rotation, and negated that rumble feel, sound.
Oscarcat
Eric
Encinitas California
I had this type of exhaust noise in other vehicles/makes. The fixes had to do with the exhaust system. I think they replaced rubber donuts that suspended the exhaust pipe with softer ones. If enough people complain maybe FoMoCo will address it like they did the dash rumble. (The dash fix uses rubber spacers up by the windshield)
