Rotors and brake pads for 2024 Ford Maverick
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
That's not great that only a small percent of your pads are touching the rotors.
Your old banned account was famous for messing with people, lol. I don't care what you think about my RR's.
I use my local selling dealer where I have a maint plan too. I'll bet they don't say squat and pass it through. They know the game and want to sell me another one...
Maverick123
Waiting
I think it's still going to stop you though. Maybe slightly slower reaction time.
Steam (water vapor) in the lines would act like a spring. It's still going to transfer force.
1000 psi is still 1000 psi.
Air - steam - water vapor - water - oil - all will move a piston in a cylinder.
Maybe it comes to a very basic level- piston travel distance.
With a liquid in the lines, one inch of travel on this end will be one inch of travel on the other end if the hose / pipe diameter stays the same. I can imagine if there was vapor in the lines it may take 2 inches of travel on one end to get 1 inch of travel on the other end due to the "spring compressing" effect.
I still can't imagine a total loss of braking power. But reduced, I can see.
OK ...
The Real Maverick
Jack
Tell me why it won't work partially.
Seriously.
You're acting as if a few water droplets will completely depressurize the system.
And then, you'll need glowing hot brakes to make it vaporize in a closed system under pressure.
I AM NOT debating this statement:
"If the fluid boils, it creates vapor bubbles in the brake lines. These bubbles are compressible, meaning they don't transmit pressure effectively. This leads to a spongy brake pedal and reduced braking power."
Temperature to get it to do that is well above 700°F. In the 1000°F range by some reports.
Maverick123
Waiting
I've seen this happen on track and cars get written off
The pedal goes straight to the floor ... You can pump it up and get a bit of braking back, but by then you've gone off the track and into the wall if there isn't enough runoff
That's why most clubs where you're driving street or dual-purpose cars will test the brake fluid for water % during pre-track tech inspection. If there's too much moisture you're not allowed on track
Coming down a super long hill with a heavy load you can encounter the same thing, and pumping the pedal won't work if there's still ways to go before the bottom - that's why they have gravel traps
I don't know what the failure mode is on heavy trucks with pneumatic brakes, maybe the pads overheat but same basic thing
wax87
Stuart
Dallas South
2004 Avalon
My truck. A 22 hybrid XLT with 49,000 miles on it, is in no need of pads or rotors. The only work I've done is bleed or replace the fluid. A 22 you do not need to hook up a scan tool, but newer models you do. The concern is on a vehicle that never gets a brake job the fluid will out live its useful life. Gets moisture in it. Ford recommends every 3 years. Last week I had a person run a red light and pull a left turn in front of me. All 4 wheels locked up just fine. Missed her by only a couple of feet. Then she looks at me like I'm the crazy person!
"Crazy Person" Are you sure she just wasn't seeing herself in the reflection of your well kept Mav?
Womyn95
Nicole
Parshall, ND
2024 Ford Maverick Lariat
Here is 2 pictures of rotors, brakes are at 8mm
Ford Maverick Rotors and brake pads for 2024 Ford Maverick IMG_4114
Ford Maverick Rotors and brake pads for 2024 Ford Maverick IMG_4115
Maverick123
Waiting
You're not braking enough, those rotors are rusting and getting scored from lack of sufficient braking
A couple times a month, find a road without traffic and do 2-3 moderately hard stops from 60 MPH to 15 MPH
Speed back up to 60 MPH and drive about 3/4 mile between stops to cool the rotors and pads
Maverick2022XL
name
hinterlands
I'd get a second opinion.32,000 miles on our 23 ecoboost and we live on a dirt road. Rotors are fine.
I have 22 ecoboost with 4k tow. My rear rotors were toast at 65K. I also tow with my truck so that probably had something to do with it.
Maverick2022XL
name
hinterlands
$1400 is total highway robbery like I said $230 for both rotors and the pads are probably 1/2 that, so maybe at most $400 in parts, so $1,000 in labor. My son and I did his Camry in about 2 hours.
You can do cheaper though it does depend on the brand and such. I got a full set front and rear ceramic pads along with front and rear drilled and slotted zinc coated rotors for ~$180 on sale from Detroit Axle on Ebay. They usually run $200 for the full set, you can get the same set with smooth rotors for ~$170 and ~$180. The only tool I had to buy or you can rent one from the auto parts store is a tool to turn the piston on the rear calipers to compress it. I got a brake cube and spent around $15 for that.
tom_tucker
mid atlantic (VA)
Me neither, it's all generator braking. Brake checking didn't work in my case and I still have rusty rear rotors. It may have actually worn out the front, as they were replaced by the dealer under a maint. plan. It was a surprise to me. Maybe I'll get new back brakes out of the deal too. I'm resigned to it. Rusty rotors for life.
Ford Maverick Rotors and brake pads for 2024 Ford Maverick 20260618_195636s
