- First Name
- Jim
- Aug 9, 2022
- Cedar Park, TX
- '22 Area 51 Hybrid FE, 2014 Impala
- Engine
- 2.5L Hybrid
OK, MTC braintrust, I need your help. My garage is very small - the Maverick barely fits. I have a large rubber "stopper" so I know when I'm in far enough to clear the overhead door, but to NOT hit the wall in front of me. My driveway is fairly steep, so I have to let off the throttle when the front wheels bump over the "lip" at the edge of the garage, lest I plow into the garage's back wall...
The challenge I'm experiencing is that I can't figure out how to make the Maverick consistently just "creep" forward. If I'm going slow enough that the "stopper" will actually stop the truck, the little lip at the front edge of the garage will also cause it to stop when the rear wheels hit it... If I'm going fast enough so the rear wheels roll over the bump, it's fast enough that I either smack into the rubber stopper hard enough to make it slide a bit, or I have to tap the brakes, which immediately stops the Maverick, and engages the "AutoHold" to prevent the vehicle from accidentally moving. Unfortunately, it takes a bit of throttle to disengage AutoHold, and then the truck "surges" forward. Out on the road, this isn't noticeable, but when you're 6" from the wall between the garage and your bedroom, it's damned scary!
I'm looking for a way to disengage the AutoHold without causing other issues, so I can "creep" forward the last few inches... The manual lists several ways to cause the system to switch off:
- Use active park assist (what is that?) (probably wouldn't work, since I'm not parallel parking)
- Keep the vehicle in neutral mode (tried it, didn't work for me)
- Driver door open (puts the transmission into Park)
- Seatbelt unfastened (tried it, didn't work for me)
- Shift into Reverse before the system is active (can't creep forward in reverse)
