Rear window rubber seal
MavPru
Rob
2023 Maverick Lariat Tremor, Jeep Grand Cherokee
I noticed the passenger rear window seal looks like it is popping loose. I took a picture of the driver and passenger window seal for comparison. Anyone else experience this? Maybe, you should check as I certainly had overlooked it .
Ford Maverick Rear window rubber seal 20230523_124730
Ford Maverick Rear window rubber seal 20230523_124747
Aspidochelone
Michael
A nearby cornfield
You might be able to silicone seal it with a little aquarium grade silicone you'd probably need a plastic clamp but i don't know how well that would work being where it is . No window seal problems on my side windows yet but my sunroof leaks. I think ford must've assumed the sunroof would leak at some point since there is a long drip tray in the back and what looks to be an absorbant foam tube in the front.
Johnkn
MD
Try putting the upper tab back in place and tapping it back in place with the heal of your hand.
Good luck
MavPru
Rob
Yes, I've tried that without success. I do think the right sealant and a clamp would take care of it. Save the hassle with the dealer. Called one already and was told I would have to leave it, and she didn't know if I could get a loaner since she was just the schedule person.
bgn
WA
There are hundreds or thousands of units with this issue. Mine included.
Renzo
Lake Stevens, WA
Ford Escape
Were you able to get the dealer to deal with it? I noticed this as well after a few days of hot weather. I'm gonna call my dealer tomorrow but I was wondering about others experiences when bringing it up to the dealer.
Thank you!
MavPru
Rob
Thank you!
[/QUO
MavPru
Rob
Thank you!
I haven't taken it in yet. Still have not decided what dealer I want to use for service and repair.
Nw_adventure
Salt Lake city
Maverick weatherstripping leaves a lot to be desired. My dealer replaced the seal in question and the whole door unit and it didn't really fix the wonky install from.the factory. These seals just don't "sit" very well.
fossil
ernie
ohio
Ford Maverick Rear window rubber seal 61D0vJrVYiL._AC_SL1200_
