Rear Speakers
Rmengel
Rick
Hartland MI
2023 Maverick Lariat
I have a B&O system and I have done the doors and tweeters. Now I'm looking for a rear speakers, any thoughts
oysterville
Oregon
2024 Maverick Lariat
They definitely helped my system, contrary to other posts suggesting otherwise. I just looked at other threads on the topic and made decisions from there.
Toddman45
St. Louis, MO
So many great aftermarket 4" speakers available. I replaced mine with kicker 4 in two ways from crutchfield, I love crutchfield because they give you the Metro speaker wire adapter harness so you don't have to cut or splice your OEM wiring.
It allows you if you ever decide to sell or trade your truck to take out the aftermarket speakers and put the shitty OEM ones back in. Crutchfield offers many budget friendly speakers options as well as high-end options.
The OEM speakers have capacitors installed to block all low frequencies to them you'll only get high frequencies to the stock speakers, aftermarket is the only way to go if you enjoy listening to music.
I'm curious what aftermarket speakers you used in the doors and tweeters in your dash?
Carlitos_92
BeardedMarine
Darrin
Oklahoma
2023 Ford Maverick
I replaced mine with Kickers. Really liked the difference.
numike
mike
car
link?
Rmengel
Rick
Hartland MI
Toddman 45, I got them all from crutchfield. I have panasonic tweeters that I think were $49 and the doors are infinity co-x which I found after are no good. speakers should only be 1 way because the sound is divided before it gets to the speaker. Knowing that I didn't use the special wires they sent with them. The front sounds GREAT and now I want alittle sound behind me. Thanks
Toddman45
St. Louis, MO
I had no idea Panasonic even made tweeters.
I use the Hertz k170 component set for the front door and dash tweeters. Then the kicker c4 two ways in the rear. I would have liked the kept it all hurts products but I didn't know until today that crutchfield carries 4-in hurts two ways I might see why they say the hurts won't fit the Maverick as the measurements seem to be pretty close for both 4" speakers. If it's something simple like modifying the tabs on the Hertz 4 in I don't have any issue doing that.
Anybody that tells you replacing the rear speakers won't make an improvement, either hasn't done it or has no idea what they're talking about cuz it makes a huge difference.
Dnel29
Regina, SK, Canada
2025 Ford Maverick Lariat EcoBoost
I see some people went into forscan and changed the rear speaker type, which also seemed to make more of a difference? Can't seem to find the post. Had something to do with giving it more full range. Different than the flat setting.
Edit: Here's a photo of the speaker settings that someone found helped the rears. Speaker 3&4 (Ignore the highlight)
Ford Maverick Rear Speakers 1718468845867-53
Toddman45
St. Louis, MO
The one that helps most, is changing the EQ setting to Flat EQ.
Dnel29
Regina, SK, Canada
If you could describe the change, what would you say?
Flat eq sets them all full range? More balanced sound?
Toddman45
St. Louis, MO
Better response at low frequencies especially if you add a subwoofer and tap the rear speakers for a signal, like I did.
I did also change the rear speakers in four scan via the ACM and easy mode from woofer only to woofer + Tweeter. I figure it can't hurt, it definitely doesn't sound bad.
jherndon
livermore calif
Ford Maverick XLT
How would you describe changing out the speakers? Easy straightforward or fairly frustrating?
BeardedMarine
Darrin
Oklahoma
2023 Ford Maverick
It's not bad. Here's a video of what's needs to be done to replace rear speakers. Start around the 2:55 mark.
wb5oxq
Waco Texas
2023 Maverick Lariat in Alto Blue
I wish it was not so hard to get to them.
