Rear Center Seat Belt Removal HOW-TO (non-destructive method)
Lane
Lane
Central Wisconsin
photos.app.goo.gl
For those unaware, people are removing the rear center seat belt in order to remove some of its parts to make room behind the seat for audio gear. I've seen other threads mention cutting the belt in order to remove it, but you don't have to. Here's what I did which should be 100% reversible. Everything should be able to be reinstalled if it's ever needed or when it's time to sell the vehicle.
1. Remove the plastic cover on the rear wall that sits over the belt and reel mechanism. Even though you're going to be careful, at least one of the fasteners on its backside is gonna break. 😡 💩
2. Pull the belt to get most of it unwound from the reel's spool. Stop pulling when you see the thick-looking end of the belt sitting within the reel's spool. Use a clamp to hold the belt to the reel bracket so the reel doesn't pull it all back in when you let go of the belt. You can use masking tape, rubber bands, whatever you have.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) IMG_0787
3. On the end of that belt webbing is a sewn loop with a plastic rod inside of it. Get a small screwdriver to pry on the loop of webbing so you can get it out of the reel's center section a bit.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) IMG_0791-001
4. When you've pulled the loop on the end of the belt out of the reel's spool just a bit, push the screwdriver into one end of the loop to push out the plastic rod.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) IMG_0795
5. Once the rod is out of the loop, flatten the loop of belt as much as you can and shove it back down into the slot in the spool. Use the small screwdriver to push it further in. You should then be able to pull the end of the belt completely out of the other side of the spool. Since there's a spring with tension on the reel, it's going to scare you as you pull out the belt as it spins up to wood chipper speeds looking for something to feed upon. Its anger will die down in a second or two.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) IMG_0797
6. You'll now have all the belt out of the end of the spool, but the loop on the end of the belt is still confined by the slot in the reel's bracket. At this point, remove the whole reel assembly from the bracket on the back of the bed which will require a pretty large Torx bit. You'll need a Phillips screwdriver to remove a small screw which holds a plastic guide to the reel's bracket. Once the plastic guide is free, you can pull the end of the belt through it and the metal slot in the reel bracket that it was mounted in.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) IMG_0799
6. Yaay! Now we've got a lot of loose belt. This photo lets you see the sewn loop on the end of the belt better.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) IMG_0802.JPG
Since the one bracket which holds the other end of the belt to the floor also attaches the rear driver's side passenger belt to the floor, we can't completely remove the loose belt unless you want to cut that bracket. Don't do that. Pull all that loose belt under the seat, fold it up all nice, and zip tie it. You can let it hang in the underseat cargo area, or you can zip-tie it anywhere else under the seat if you want it further out of the way.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) IMG_0806.JPG
For the now-orphan latch/buckle, I just pushed it down into its seat opening so it's no longer visible (a bit beyond what's shown in the photo below). How do you know which is the right buckle? I took a guess that the center buckle was the one that didn't have wires running into it for detection of whether it was latched.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) IMG_0808.JPG
With the reel mechanism now removed, you'll be left staring at the large empty mounting bracket on the rear wall where the whole works was attached. I'd love to have the space available where that bracket sits, but its removal would mean that this process becomes irreversible and I wouldn't be able to put everything back to the way it was. So for me, it's going to stay.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) IMG_0814
Here's a pic to show the parts a bit better. #1 is the slot in the reel bracket that the belt passes through, #2 is the plastic insert that sits in that slot that needs to be removed to pull the belt through and out. #3 is the plastic rod that sits inside the sewn loop in the end of the belt and holds the end in the reel itself.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) Img_0812a
I hope this helps others wanting to get all this stuff out of the way without having to break or cut things.
likeparty
Marty
Groveland FL USA
2023 Maverick XLT Hot Pepper Red
What an outstanding write up. Thank you.
DId you by chance try to get the seat out the door as a unit?
I'd rather not have to undo the hinge as the bolts holding the hinge to the back come in/out pretty easily once you have the trim piece off.
I have an XLT and want to be able to replace the seat when we have company. My car only sits 2 people and without the rear seat the bike fits but then we have 2 two seaters.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) Beast Red Corvett
Lane
Lane
Lane
Central Wisconsin
photos.app.goo.gl
As a part of removing that center belt, I did not remove the seat. I did that with the back just leaning forward.
More recent work on the audio system did require me to remove the rear seat, but I did so in two steps. Two bolts to remove the seat back, and two nuts to remove the seat bottom. This made the job manageable for one person, even though the brackets on the sides of the seat bottom are sharp and will absolutely scratch any plastic trim they touch. :rolleyes: If you wanted to remove both parts of the seat as one piece, you'll need two people and extra care.
You take out your rear seat to fit a bike inside? Why not put the bike in the bed? Or get a hitch-mounted bike carrier? To me, either of those options would be preferable to removing and reinstalling the rear seat.
GNprime
Ohio
2024 Maverick Lariat
Granted this is an old thread, but I just wanted to say thanks for this write-up! I finally got a warm enough day to roll down all my windows and I thought I was going to lose my mind listening to the belt slap against the seat back. I got ready to just chop it off. But I decided to listen to the little voice in my head and google it. This was exactly what I was looking for! It took me longer to get my tools out than it did to do this! Thanks much!
Dan2141
Ohio
2026 XL AWD 2.0 Ecoboost w/ 4K
Any advice on Step 1? I don't want to break anything.
Cancunbadlands
Cancun
Cancun
Get a hitch-mounted bike carrier
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) 20251122_131236~2
Lane
Lane
Lane
Central Wisconsin
photos.app.goo.gl
It's been 2-1/2 years since I took it apart so I don't recall the details of specific fasteners. Best thing to always do is to get a flashlight and peek behind a panel as you pull pull it away from the vehicle slightly. Often that allows you to see where the fasteners are and the direction that the panel needs to be pulled. And if you can't get your eyes at the right angle, a small mirror helps.
I've used this enough times over the years that it's very worthwhile to have:
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) 1771280743796-aj
Search Amazon for 'angled telescoping mirror'. Well worth it.
A panel removal tool goes even further and provides leverage to pry the plastic fasteners rather than pulling on the panel that they're attached to.
Ford Maverick Rear Center Seat Belt Removal HOW-TO (non-destructive method) 1771280882927-1h
Harborfreight.com has both of these tools.
Dan2141
Ohio
Okay. I have an interior panel tool kit but not a lot of experience. I guess I'll just pry around and hope for the best.
