- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
Actually the AC is 3-phase running from the HVB system, not the 12V system.There is no "leaving it idling" for hybrids, with the key on & not driving the hybrid traction battery will be charging the 12VDC battery which will be running AC or whatever if its on.
Only when the traction battery is fully depleted from charging the 12VDC battery running the AC & music or whatever, will the PCU turn the engine on to recharge the traction battery if not driving or running AC depleting battery to nothing, the engine will not start even with the key on.
Just let the hybrid PCU do its thing, found out if the engine kicks on its better to step on it get some speed, especially in winter, & gets battery recharged so engine switches off & running on battery power.
What I found so far is Nursing the engine throttle in winter is the worst thing for gas mileage, the battery needs to be warmed up for optimal use & that happens from an exhaust heat exchanger - double whammy the cold battery is inefficient and the cold not at operating temperature engine is running a richer fuel air mix burning more fuel.
But indeed the HVB is charging the 12V system and battery.
And it's not actually fully depleted - it's 30% SOC, ICE will turn on until up to 40% SOC on the HVB.
Unless the 12VB is just in a terrible state - in which case it'll go up to 55% SOC with ICE on.
Just saw that today. (allows for higher charge to 12V battery without the ICE just starting up and running again sooner)
What warms up the HVB even better than exhaust heat - couple applications of regen for a decent distance/time - which the system will do appropriate current for the temp, but keep adding more amps until it's warmed up faster than the exhaust can get it on a cold day.
I've seen 2 short regens on hills warm it up to accepting full amp potential, compared to over 1 mile drive and still not as warm.
Obviously for most drivers - options for where you are going for 1st drive of day is limited - you get what you get. But if you have a slowish 35mph slight downhill section option - pretty good!
