Put steel wheels on xlt lug, stud
GreyCacti
Jake
new England
21 Prius prime
I found a set of 4 245 65 17 tires for $480.
They are on steel Maverick Wheels.
I have an XLT with alloy wheels 225/65 17.
My question is will I be able to just put these larger tires on steel wheels directly onto my truck? Should the studs, lug nuts and tpms sensors all be plug and play?
MaverickDragon
Grand Canyon, AZ
Maverick XLT and XL trims share the same wheel dimensions and bolt pattern.
More than a few on the forum use the XL steelies on their XLTs for winter tires.
There should be no problem with remounting the existing sensors you have on the steel wheels, or just keeping the sensors you have on your alloy wheels when swapping the tires.
Not sure what you are asking...
Are you planning on using just the tires?
If so keep the tpms sensors you have on your wheels.
Do you plan on using the steel wheels instead of the alloy wheels?
There was a tpms change from 315 MHz to 433 MHz at some point, but you don't state the age of the wheels or the vehicle you are putting them on.
If incompatible, put your trucks tpms sensors on the steel wheels, otherwise. you may be able to use the tpms on the wheels you buy, assuming they are functional.
GreyCacti
Jake
new England
21 Prius prime
Thank you, I have a 2024 Maverick hybrid 2wd
I found a set of steel wheels with tires, and existing sensors in them.
My goal was to buy this new set of steel wheels 245/75/17 to replace my alloy wheels that were 225/75/17.
The steel wheels do not have the center cap, or lug nuts. I was hoping that I could use my lug nuts from my alloy wheels to put these new larger steel wheels on my truck. The seller said the sensor should work for 2022-2025 Mavericks
Johnkn
MD
The steel wheels are not larger, the tires are larger.
The lug nuts for the steel wheels are open ended and are different from all other Maverick factory wheel options.
TPMS Sensors for 2022-2024 Mavericks are 315MhZ
TPMS Sensors for 2025-2026 Mavericks are 433MhZ
The sensors are not interchangeable outside those model years..
MaverickDragon
Grand Canyon, AZ
The 225 and 245 designations are the tire size, not the wheel size.
The wheels are both 7 inch rims and either tire size should fit on either wheel set.
The tires from the steelies can be put on your rims, or are they in bad shape?
Johnkn
MD
I would like to take my alloys off and run these steel wheels instead.
Like pulling teeth.
"Run those steel wheels" (and tires)?
If you care at all about MPG, handling, performance and comfort you won't. Those Coopers weigh 50% more than your stock tires.
If you don't care about those attributes have at it and good luck....
Let me guess, they're on Facebook Marketplace? Guess why they're for sale? Hint: not because the current owner really liked them.
GreyCacti
Jake
new England
21 Prius prime
Like pulling teeth.
Yes the wheel and tire combo.
I found them on marketplace, I figured for the price it's cheaper than buying two new falken AT trail tires.
GreyCacti
Jake
new England
21 Prius prime
I am going to be ordering the correct lug nuts. If these tires take too much mpg away I will just use them for winters and switch back to the alloys for spring- fall with a cheaper more fuel efficient tire being on the alloys
Does anyone have any center caps that they are willing to part with?
FredsMaverick
Fred
Forest Hill Md
2026 Ford Maverick Hybrid AWD
Usually the tires that come with the truck are 225/65/17. You say the new tires are 245/75/17. I guess the wider tires will fit?
GreyCacti
Jake
new England
21 Prius prime
That is what I am reading/ hearing.
I didn't realize I needed different lug nuts. I am ordering those online, I'll need center caps too.
It is the largest size that fits stock without rubbing I read.
Robot-Wrangler
Kentucky
I used the chrome lug nuts designed for the steel wheels for my winter and all terrain driving so the center caps are retained. I used the OEM aluminum wheel lug nuts for the Mustang Mach-E wheels.
Ford Maverick Put steel wheels on xlt lug, stud 236168-c56c7e480a6428bd998d877870a81a68
Ford Maverick Put steel wheels on xlt lug, stud 20250710_170011
GreyCacti
Jake
new England
21 Prius prime
Those look great, I did not realize the mach e rims would fit the Maverick.
I currently have the xlt alloys on my Maverick. I want to put the steel wheels on for getting firewood, and also for winter to keep Alloy Wheels in good shape. Being in New England I am afraid that the salt on the roads is going to ruin the painted alloys.
I will look online because I want to get the same center caps that came with the steel wheels stock otherwise it will look funny having a hole in the middle.
The wheel tire combo that I plan on buying does not come with the center caps or lugs.
