Problems w/ Side Marker Light swap to LED
Jamers99
Jason
Tampa, FL
2023 Maverick
Fo the life of me I can not get the Driver's side marker light off in order to swap with an LED. I was able to replace the passenger side by going thru the wheel feel area. The video I saw on F150LEDS.com on how to remove this side marker light make it look easy. This thing just doesn't want to come off and you can't access it from the behind. Any suggestions?
Ford Maverick Problems w/ Side Marker Light swap to LED Image 5-11-23 at 4.03 PM
jewc75
I accessed it from the back. It was easy.
jewc75
There was enough room even with the computer in the way.
Jamers99
Jason
Tampa, FL
2023 Maverick
Did you access from the wheel well? I ran my hand around there for 30 mins and couldn't locate any access tot he back of that side marker.
jewc75
Yes. Removed the screws and it was right there.
Jamers99
Jason
Tampa, FL
2023 Maverick
Anyone else successfully access the driver's side marker light from behind? I feel like Jewc75 is punking me. :ROFLMAO:
Jamers99
Jason
Tampa, FL
2023 Maverick
Do you mean you accessed from the wheel well area or did you come from underneath somehow? Just doesn't seem like my hand can fit anywhere in there.
mdl20813
Idaho
Cactus Gray Maverick XLT
It cost me some skin and blood but I also pulled the stock drivers side bulb from behind after not being able to pull the lens out from the front. Probably could have gotten it but wasn’t willing to risk breaking a mounting tab
Jamers99
Jason
Tampa, FL
2023 Maverick
I'm having the same issue. Can't get side marker light off. How did you access it from behind on the driver's side? There is a computer there or something.
mdl20813
Idaho
I pulled the wheel well felt liner back. I had also removed the plastic spats in front of the tire previously which created a little more room. That gave me just enough room to snake a hand in, pull the harness, swap bulbs and plug back in
Jamers99
Jason
Tampa, FL
2023 Maverick
OK, I tried that with no success last night. Did you snake your hand between the bumper and the computer thingy?
Big Zig
North Jersey
2022 Maverick lariat
me too but i had to find the right tool i did n just keep pushing up and out
TRUCKHEF
SOCAL
22' Ford Maverick XLT
it slides forward and pops off, I used two trim tools one to push forward and another to lift up and pop off, it’s not easy but very doable
Rentman1225
Greg
Rockford, IL
Forde Maverick XLT LUX
That is what I did.. I also covered the painted areas near where I was prying with painters tape. I'm not sure if that helped prevent any marring or not, but I didn't have any. Your mileage may very.
