Problem with Ford hard roll up tonneau cover
Backin15
Frozen Minnesota
2025 Maverick XLT
I bought a hard rollup tonneau cover from Ford using my points and a Memorial Day discount, so it is just a couple months old and spends most of the time in the garage. I noticed the rubber weatherstrip is coming loose at the end, there doesn't seem to be much adhesive on it. It is sticking well the rest of the way and the other side is fine. Not sure if I need to go through Ford or the manufacturer of the cover (I think it is BAK?) for a warranty claim? I am also thinking of just fixing it myself, but not sure what adhesive will stand up to the heat and moisture. Ideas?
Ford Maverick Problem with Ford hard roll up tonneau cover 20250808_080345
Maverick123
Waiting
OEM, accessories have factory warranty so you should be "covered" 😄
OleKennyRoy
Kenny
Maverick Lariat
I'd think you'd need to go through Ford, but I'd see about ordering the parts from BAK to upgrade to the X4s with endcaps.
Backin15
Backin15
Frozen Minnesota
2025 Maverick XLT
That would be nice to get the upgrade! I doubt they will go for it though.
Cancunbadlands
Cancun
Cancun
OEM Ford accessories have factory warranty
Gamma500
2022 XLT
Go the warranty route as previously suggested.
FYI, I have the same tonneau (it is BAK) which had a similar issue at the other end of the box, it was just past warranty. I smeared a product made by “Gloozit”. It’s marine and rv adhesive. It’s still holding, flexible, waterproof and transparent. I would recommend if all else fails.
OleKennyRoy
Kenny
Maverick Lariat
It's just four plastic pieces that need to be changed. Two tabs that go into the cover, and the two caps that snap on.
The rubber weather strip gets trimmed back a couple inches.
would look like this:
Ford Maverick Problem with Ford hard roll up tonneau cover 1754742986968-m3
Elderchuck
Curt
Minnesota
2025 Ford Maverick Lariat
At least your rubber strips make it to the tailgate. Mine came from the factory with the rubber touching the window leaving gaps at the tailgate which helps clean out the box in a car wash or rain 👎. Dealer recommended that I buy the caps suggested here. Why is this my problem? Would not buy this cover again on this issue alone.
Backin15
Backin15
Frozen Minnesota
2025 Maverick XLT
I like that endcap kit! It gives it a nice finished look. I am going to send that to a friend of mine with the same cover on a Frontier, he has a 1/4" gap at the tailgate.
Mervin the Maverick
Ken
Sierra Vista, AZ
2019 Kia Niro, 2019 Hyunda1 Kona, 2002 Chevy S10
Yup Same issue here! I had warranty replacement once, but check this out:
Ford Maverick Problem with Ford hard roll up tonneau cover IMG_4343
Ford Maverick Problem with Ford hard roll up tonneau cover IMG_4340
Ford Maverick Problem with Ford hard roll up tonneau cover IMG_4342
Ford Maverick Problem with Ford hard roll up tonneau cover IMG_4341
Mervin the Maverick
Ken
Sierra Vista, AZ
Still waiting after a month to hear what Ford wants to do next.
Yes, it was 102-degrees here today, but I would think that Ford knew they would sell in Southern Arizona!!!
Backin15
Backin15
Frozen Minnesota
2025 Maverick XLT
The top of my side rails have ripples, but nothing on the sides where it is very visible. That is a nasty buckle you have there, I can't imagine they wouldn't replace that for you.
Mervin the Maverick
Ken
Sierra Vista, AZ
Right! But I took it to the Ford dealer on July 7th, and he says “I haven’t heard anything yet.”
Backin15
Backin15
Frozen Minnesota
2025 Maverick XLT
I went to the dealer, they said this is a common issue. The fix is to replace the entire rubber strip. They looked at the other side, the very end of it was coming loose as well so that one will be replaced too. The fact that I installed it myself seems to have complicated things, as now it has to go through the parts department, and they will have to go through the manufacturer. Luckily I cut the sticker off the box it came in that had the model and serial number. They said it will take a couple days, but will call me when the parts are in.
Mervin the Maverick
Ken
Sierra Vista, AZ
I’ve been waiting since July 7th to hear about my warranty claim because my hard roll up has had the same issues. In fact, it’s already been replaced once. I’m waiting for Ford to live up to their warranty!
