Pre collision assist not available stuck in park
Escapologist
Niagara Region, ON
Dielectric grease is not conductive.
So that being said not advisable to use to improve conductivity, for preventing water intrusion and corrosion resistance yes.
Yes, it's to stop further oxidation and moisture intrusion. Never had to touch anything again that I put back together with it, dodgy inline connectors, lamp sockets, you name it.
Oandrews
Orvis
South Eastern USA
'25 Tremor
Some folks think dielectric grease improves the connection, it keeps it from getting worse.
Ms. Loretta
Los Angeles
2024 Maverick Hybrid
Had a similar issue, it was the speed sensor that got cut when I hit a pothole. Thankfully a simple fix. I had a similar issue with my MKZ a few years ago and it was due to some mice chewing on the wire harness
Escapologist
Niagara Region, ON
You'd want Coolamp conductolube for that and it's best not placed in the hands of amateurs who will short everything out with it.
Busl0adofnuns
Busl0adofnuns
Brandon
Somerset, ky
2024 ford maverick xlt, 2018 ford flex sel
So here is what they found this morning and replaced
Battery
Break switch
Here's to hoping the problem goes away
I want to thank everyone for the input. it was extremely helpful I went Into the dealership this morning with no your fixing it attitude, with knowledge from the community of owners. Thanks again to everyone!
Ford Maverick Pre collision assist not available stuck in park 20251103_135750
Battery
Break switch
Well looky there you battery abuser!
Its been checked a few times already
So far my battery has been good first thing they checked. Mine also wasnt part of the recall at all. I fussed about that already. I have amp and speakers installed, but it was doing this way before all that.
Hmmm
Busl0adofnuns
Busl0adofnuns
Brandon
Somerset, ky
I know right I would have thought it was the battery after being in the shop 3 times
Yelp I was definitely wrong on that front. Thinking it couldn't be it. Assuming they would have seen it by now.
I guess the frustrating part of it for me is that the service department should have looked at the battery condition first. Then started replacing parts.
I would also ask them if they can increase the 12 volt battery charge to at least 90% if not 100%.
Busl0adofnuns
Busl0adofnuns
Brandon
Somerset, ky
Mines a '25. It happened on day 2 of ownership.
4 days for me was the first time. They got the shifter part fixed. They did a battery and break switch.
Busl0adofnuns
Busl0adofnuns
Brandon
Somerset, ky
Well its not fixed just got stuck in park again same warnings again
Oandrews
Orvis
South Eastern USA
'25 Tremor
So, new battery and gear selector switch didn't fix it.
Are there any other dealers near you to take it to?
If your dealer has more than one, switch Service Writers.
