power train problem
logan78
logan
ohio
2022 ford maverick
I have 2022 ford maverick with 3600 mile was at the dealer they did the axil recall ever since then I have a vibration when in in drive or revers with your foot on the brake and vibrat like really bad then when you drive it bit then park it get a really bad vibration
matmondro
Mathieu
Vassar, MI
I have a similar thing as you're describing: vibration when foot is on brake while stationary. Wouldn't say mine is extreme, but once the weather warms up I am going to check on my motor mounts. Suspect it could have something with that.
I'd take it back to the dealer though.
Larrythelunatic
Larry
Massachusetts
92 Toyota Pickup. 22 IS hybrid Maverick. ‘25 Hybrid RAV4
You have a hybrid.
When the truck is on (“ready”), do you feel the vibrations (while stationary) while the engine is NOT running?
Trying to isolate a suspension issue from an engine issue.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
You have a hybrid.
OP shows they have an EB…
Timothyd
You're gonna have get insistent at the dealer. Put something is writing too. You can't put up with that.
LouieIV
Louie
Griffin Ga
Chevy Colorado
I have a issue with this too. I wasn't sure if I was just imagining things because I went from a 22 EB FX4 to a 23 Tremor. I thought maybe it just drives slightly different. But I notice that when I hold the break down and put it in drive, it vibrates a bit and gets slightly noisy. Not much, but noticeable and my 22EB did not do this whatsoever. Seems to be worse is I cut the AC on. Strange. I wanted to drop it at the dealer but they said they need it for a few days before they can look at it. I'm blue collar and cannot just drop it off and have no truck for days. Not sure how to handle it.
Timothyd
You just might have to break down and rent something. They should pick up the tab if it's warranty. Or take it to a local repair guy and get a determination before you go to the dealer.
bgn
WA
Motor or transmission mount likely. I'm pretty sure mine are shot because I dropped the front end into a gravel road water bar going quite fast with heavy tires. 😁
logan78
logan
ohio
2022 ford maverick
I do a lot of Offroading for cutting wood so that probably the issue
  • Like
Reactions: bgn
