Power outlet in bed fitting question
sprcoop
AZ
2023 XL Hybrid, 66 Mustang Coupe, 2012 Focus DCT
I want to put outlet(s) in the bed but don't want to use the cubby doors or inside the cubbys. I'm using them for storage.
Does anyone know if a single marine power outlet (cig lighter style) that will fit in the piece I have circled? Anyone have a part #?
Something like this?
Cigarette Lighter
Ford Maverick Power outlet in bed fitting question BedPowerOutlet
RichardCranium
R
I have seen it put there before. Tight fit, if I remember correctly.
sprcoop
sprcoop
AZ
I have seen it put there before. Right fit, if I remember correctly.
As soon as I posted this I thought maybe I could figure it out by measuring. Duh!
The link I posted shows 1.4" OD and the part that gets inserted only 1".
Measuring between the molded guides on the back side of that panel is ~ 1.8".
I'm thinking good to go. Here's hoping this post will help someone else!
RichardCranium
R
sprcoop
sprcoop
AZ
RichardCranium
R
yeah, I remembered seeing it before, couldn’t remember where. I was glad I was able to find it for you. Probably get that one printed for less.
Hot Runr Guy
West Chicago, IL
I'd double-check that width number. I just popped one out, it's a lot closer to 1-3/8"-1.4". The hex on my Blue Sea outlet is a snug fit.
HRG
Ford Maverick Power outlet in bed fitting question IMG_0963
Jone
Jonathan
Mi
2024 Mav
Am I missing something? It would be very rarely that I would use my power outlet. Maybe tailgating at a football game but that’s about it.
sprcoop
sprcoop
AZ
No, you're not missing anything. Most folks would never miss it.
For $10 and a few minutes to put it together I figure it's better to have it and not need it than need it and not have it.
I'm thinking of going crazy and putting USB A and C in the other side. But I'll need another pig tail.
sprcoop
sprcoop
AZ
HRG
You're right!!! WTH was I measuring?!?! It's more like 1 1/4".
Luckily the file that Richard was kind enough to link to will 3D print with the correct size hole.
Idiot proof! Of course as soon as you start thinking that way they make a better idiot.
Carlitos_92
My thoughts exactly. (y)
Maverickman74
Shane
Maui HI
Sorry I dont have a better pic but I just got the simplest most basic one at either autozone or oreilleys. I used a pair of wire snips to cut the plastic structuring off of the back of the cover. Then drilled the hole with a harbor freight step drill bit until it was a nice screw in tight fit. It has a little flap but it usually has the plug for my fridge in it. Only issue is the cover itself is a little easy to pull out so sometimes you have to pop it back in. If you twist the plug as you pull it out it stays put. On the opposite side I put in a flush pushbutton for the cargo lights.
Any parts store that has a good accessories section should have what ya need. A truck stop is a good place to look too. Here is one on amazon like the one i have.
Amazon.com: Cigarette Lighter Socket Car Marine Motorcycle ATV RV Lighter Socket Power Outlet Socket Receptacle 12V Waterproof Plug by ZHSMS : Automotive
This one is interesting in that it may be a perfect fit to replace the whole panel.
Amazon.com: DaierTek 12V Cigarette Lighter Socket Replacement Female Connector DC Socket Power Outlet Cigarette Lighter Outlet with Wire Fuse and Waterproof Cover for Car Marine Boat Auto : Automotive
Might have to use bolts like these. Found at any hardware store.
Ford Maverick Power outlet in bed fitting question {filename}
Ford Maverick Power outlet in bed fitting question IMG_20230925_173331_129
Ford Maverick Power outlet in bed fitting question IMG_20230924_123404_460
SVTRIDE
SE Michigan
2024 XLT Maverick
I merely drilled a hole in the cover the same size as the outlet I wanted to connect. Have had no issues in 2 years.
KISS…way to go.
