Poor man's sub solution
Tom201326
Khoa
Orange County, California
2004 Jaguar XJ8, 2021 Honda Insight EX, 2023 Mav
Hardware used:
- Boss 4 gauge amp kit (Ieaving that in place if I ever need to upgrade my sub :))
- Sound Laboratory LoPro 8' Subwoofer
- 3M tape
- Zip ties
- Wire taps
- Micro 3 Add-a-fuse
Ford Maverick Poor man's sub solution 20231106_114150
This is how the sub is mounted for the moment. After testing it and make sure everything works, I'll make a permanent mount for it that doesn't take the scissor jack. (Spoiler: It works!)
Ford Maverick Poor man's sub solution 20231104_133758
This is where I tap the wire for the speaker level input, which is the radio harness behind the HVAC control panel. I could've tap into the rear speakers, but I'm afraid of audio interference.
For the remote turn on wire, I used fuse #1 under the passenger footwell, which only gets power if the key is set to the "On" position. Fuse #3 or #6 should work as well, except it's micro 2.
Ford Maverick Poor man's sub solution 6abe4339-cba0-49bc-8720-b73007006a16
This is where I mount my sub control knob. I used 3M double sided tape so I could move it easily if I wanted to.
For under $200, it pretty much filled the bass that's lacking in the Maverick's audio system, and I'm very pleased with how it performs.
Slimshady
Marshall
Middle TN
1989 Ranger,1995 Ranger,2002 Ranger,2023 Maverick
it will sound way better if you mount it under your rear seat...in the storage compartment....just cut a piece of wood to mount it to and set it under there...or for just testing purposes set it under there loosely , put the seat down and have a listen..
Tom201326
Khoa
Yeah, I initially planned that, but the sub is so wide it couldn't fit down there all the way. Plus, I've seen most users mount it behind the rear seat. Works pretty well for me :)
thev8man
Hardware used:
- 3M tape
- Zip ties
- Wire taps
Booyah 👊🏽 😁 👍🏽 🇺🇸
I m in,
Hardware used:
- 3M tape
- Zip ties
- Wire taps
Booyah 👊🏽 😁 👍🏽 🇺🇸
I'm in, was your truck an XL XLT or Lariat?
Did you change you actual speakers.
And where did you get the sub?
Gullzway
OK
1968 Ford Mustang Fastback
My Kicker Hideaway 8 sounds great under the back seat. Doesn't fit perfectly, sits at a bit of an angle. I mounted the Bass control under the console USB port area where you can't see it.
Got it Open Box at BestBuy for $165. Available for $210 now Open box Excellent.
Ford Maverick Poor man's sub solution original_f54a2f19-7c41-405e-aaf4-27a081a81f24_PXL_20230303_170658622
Tom201326
Khoa
Booyah 👊🏽 😁 👍🏽 🇺🇸
I m in,
Booyah 👊🏽 😁 👍🏽 🇺🇸
Mine is the XL, and I did replaced the front speaker, but it doesn't add enough bass for me.
Tom201326
Khoa
Looks good, mine just barely fits in there lol.
The Cyber Orange Guy.
Devu
Caribean
Maverick cyber orange
Looks good, extra points for the 165$ deal. Enjoy.
