Panda BPV Delete Kit - installation?
Adamyoung
Adam
Standish Maine
Jeep Wrangler
Doing the cheap panda bpv delete @panda, when I remove the tube does the cap go on the intake end? Haven't went out to do it yet but I'm doing a cai at the same time, any tips on the bpv delete thing would be appreciated, it's just to hold me over till I get a real bov. @Mitch Panda Motorworks @Caleb@PandaMotorworks
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
Helloimnormal
Somewhere
Intake side gets capped. Hose should just be open.
georgeb
George
Temple Terrace
Maverick AWD 4k
This is a small PIA to bigger PIA depending on how accessible your BPV clamps are.
I got lucky and mine were both facing up.
Instructions:
1. The left side clamp (passenger side/attaches hose to intake tube) - grab it with some man pliers and move it all the way to the right side of the hose as far as it will go toward the BPV - making sure to keep the clamp ends orientaled correctly so you can grab them later.
2. Take a large flathead screwdriver and pry it under the hose. Do this to break the hose loose on the front/back/top of the left connector. Then pry the hose/stretch the hose with the screw driver wedged in. Use some common sense. I wedge it straight in - then tilt it upward - while nudging the hose toward the right. The hose can stretch quite a bit.
3. Eventually it will flex in the middle and you can work it the rest of the way off the left side.
4. none of this is easy.
5. Grab both clamps and move them to the left side or off the hose completely.
6. Work the hose by hand the rest of the way off the BPV.
If your clamps are facing downward - gonna be more invatsive.
Review coming tomorrow maybe.
georgeb
George
Temple Terrace
Maverick AWD 4k
Review: it works. its loud. its ricey.
I would say its a novelty mod - and thankfully reversible if you get tired of it.
