P04F0 CODE LARGE LEAK
SPLMAVERICK
Alexander
2022 Ford Maverick XL 2020 Hyundai Elantra
So I'm an original owner of a 2022 Ford Maverick 2.0 ecoboost truck. It has been a great truck untill this morning on my way to work a P04F0 popped up so I turned around and headed back home. 9nce there was light out ( I leave at 5 in the morning California) I started doing my research on the code. Looked at chaffed wire under the driver side seat( under the truck and the mesh covering) no signs of broken wires and all connections are soild both electrical and fuel. Nothing loose or anything like that. Check ylunder the hood all good. Read about evap lines rubbing towards the back driver side wheel. Found my problem the clip that separates the 2 lines has been vibrating and rubbing to the point that it destroyed bothe line causing my P04F0 code. There is no tsb and my local dealer wanted my truck over the weekend to figure it out. Not falling for that trick. Didn't want to take the risk of them having it and telling g me its other parts that are wrong at that they are not covered by warranty and having it for a week and a $1000 dollar bill for what I can fix foe 20 dollars. My truck is garage kept its whole life with no rodents. At work I park in. A concrete parking lot with no rodents either.
Point of the story is Check your ecoboost for this problem you don't even have to remove anything just kinda push to the side the covering and thro some light in there. Hope this helps any body's who has had this issue. In the last picture you will see the clip that causes all this damage.
Ford Maverick P04F0 CODE LARGE LEAK 20261023_122728
Ford Maverick P04F0 CODE LARGE LEAK 20261023_121559
Ford Maverick P04F0 CODE LARGE LEAK 20261023_122202
Finnster
N. E. Wisconsin
That is a lot of damage! Please let us know what you do to repair it. Thanks.
Cancunbadlands
Cancun
Cancun
Are you leaking gas?
SPLMAVERICK
Alexander
No leaking gas its vapor return lines so I just bought some fuel lines and clamps for now. Going to see what the dealer says about covering it under warranty. Chances are I'll be replacing the lines myself. For now it works fine. I also put some tap on the electric wire because it was showing signs of wear. I don't go off roading or anything like that either. Just highway miles mostly.
Ford Maverick P04F0 CODE LARGE LEAK 20261023_142101
Ford Maverick P04F0 CODE LARGE LEAK 20261023_143653
Ford Maverick P04F0 CODE LARGE LEAK 20261023_143933
  • Like
Reactions: Dad
rick52
Rick
2026 Maverick / 1967 Mustang Restomod
My guess would have been rodents. Was the damage under that piece that holds the two lines apart? The gas lines AND the nearby wire...coincidence? The way the lines are shredded just doesn't look like damage from mechanical abrasion.
Brianx
Pennsylvania
'24 Eco Boost XL Cactus Gray, tow bar, Co-Pilot
never saw rodents leave long strands like that. maybe someone with a knife
SilverBullet2.0
Josh
2025 Ford Maverick Lobo
Did your fix clear the code?
ianjay
Ian
Toronto, Ontario, Canada
2024 Maverick Lariat Hybrid , 2008 Ford Ranger
A rubbing clamp would leave smooth marks. This is anything but smooth. Definitely rodents. Good fix though. Probably last the life of the vehicle.
Tim d
Alpena
Ram
This is at the drivers side rear wheel well? Thx for sharing.
SPLMAVERICK
Alexander
Yes it was definitely caused by the piece that separates the line. Wear marks on both line line up perfectly and you can see scraping on the metal piece behind the lines. The part that holds the line together works loose and my 80 mile drive to and from work caused the damage. I video documented it along with keeping the shards that came off. Either way there is no T.S.B. Just doing my do diligence and warring fellow owners to check before it happens to them. Mined you this happen in 1 day. Fine on a Thursday then driving to work on Friday it threw the cell and drove back home to discover this. As far as the wire you can see on the felt that its been in contact with the wire. I simply put a little more buffer between the 2 areas to prevent it from fraying and causing a bad single to the pcm.
SPLMAVERICK
Alexander
I disagree but to each there own. I was born in Califonia and have had at least 1 dozen vehicles and never had issues with rodents. Maybe in your area if the county but not mine.
Marty
2026 Ford Maverick Tremor
That is definitely rodents. Easy to tell once I zoomed in.
