On Board Tire Pressure Reading
dalola
Retired
SE Ohio 🇺🇸
I mean how do I bring it up on the screen, to see the 4 pressures. Ray charles knows how to put air in tires
It's a menu item on your meter screen. You have to select it if you want it to display on the scroll, because it won't scroll thru all menu items. Read your manual for specifics on how to do that.
zzbaluba
Olathe, Kansas
2023 Maverick XLT Alto Blue
My Mav has been wandering a bit lately.
I checked the on board pressure which read 31 psi all around. I inflated to the recommend 35 psi using a trusty guage of my own. The Mav display now shows 42 psi.🤔 Has anyone else found that the on board display is not accurate, any way to calibrate it if so?
Thank you!
My onboard pressure readings are right on target with my classic stick-type tire pressure gauge.
BlueXLT
IA
Ford Escape
My TPMS is about five higher than both of my manual gauges.
todd92
Own 5 Ford's, TPMS is 100% accurate on all of them.
