Oil pan shield bolts stripping out
Gpp
Gil
Sanford nc
2022 ford maverick
Am i the only one who strips these oil pan shield bolts.would it help to get metal fasteners that the bolts screw in to and trash the plastic ones?
🤔 Nope
I am sorry, I do not have the link anymore either Amazon or Ebay.
I bought a bag of metal spring nuts. plastic push nuts and screws, along with a bag of oil and drain plug washers. Just to have on hand.
Ford Maverick Oil pan shield bolts stripping out Screenshot_2024-12-30-18-27-18-62_40deb401b9ffe8e1df2f1cc5ba480b12
Toddman45
St. Louis, MO
I've done two oil changes so far on my EcoBoost didn't have any issues either time. I used a torx bit adapter in my battery operated drill on low setting.
I would agree that the little screw inserts are the weak point but so far they work.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
Unless yours are different..
They are "Metal" not Plastic...
Ford Maverick Oil pan shield bolts stripping out Engine Shield fasteners
I forgot one, on my last oil change... :confused:
They are of a "Cheap" design..
I have seen these before, (I did post on these in another thread, sometime ago.)
This setup was/is used for attaching interior trim panels... (Rangers).
I will "Hand-tighten" the screw/bolts before snugging them tight. With any kind of wrench.. ;)
You would have to find, a "nut" that will stay retained in the sheet metal.
Of the underframe...
Jerry
Exranger
Northern California
I used 6mm (I think) threaded bolts on my wife’s focus, same clip. Threads instead of sheet metal. She never ripped the cover off after that. Same bolt as Mercedes uses for the panel.
M6x1
https://a.co/d/7ihBb9m
BlueSpec1
Gene
Amazon bag looks like:
https://www.amazon.com/dp/B0CN3BW9Z2
Engine Splash Shield Guard Undertray Cover Screws Bolt Nut Clip Torx Pan Head SEMS Tapping Screw for Ford W702413-S450B W702438-S300 Lincoln Continental
Ford's inserts and screws:
W702413S450B - Fender Liner Screw - Ford (W702413-S450B) My XLT are TP27 Torx Plus
W718770S439 - Lower Shield Nut - Ford (W718770-S439)
For rear of Maverick wheel liners area, I got some of these in case I broke a clip:
https://www.amazon.com/gp/product/B0BJPYZQ74
https://srfast.com/product-category/manufacturer/ford/page/1/
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
That Assortment set from Amazon might work.
Though....
A = would work, IF it snaps into the existing hole size...
B = will ONLY work, IF the hole is near the "edge" of the sheet metal.
Meaning, it has to "Clip" over the sheet metal.. Than the screws passes though..
Ford Maverick Oil pan shield bolts stripping out Amazon Clips
Jerry
Gpp
Gil
Sanford nc
2022 ford maverick
Though....
Jerry
I definitely am going to try some metal clips and screws! I am To old to use plastic screws or clips🙃
Tim d
Alpena
Ram
The bolts are made of plastic? Seriously?
Toddman45
St. Louis, MO
No only some of the bolt retainers are, only spot off hand I can think there are plastic nut retainers is for the center high mounted rear brake light.
Exranger
Northern California
Though....
Jerry
Yes you are right they only work with the plastic clips. They do fit those very tight. Thanks for the clarification.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
I haven't had to disassemble too vehicles.
The last one was my 2nd Ranger. I did some trim and door work.
I remember seeing...
Plastic clips, plastic bolts, plastic plugs (these have a large head and a barb for the screw section).
Most of the clips metal/plastic were used on oversized holes in the sheet metal.
Easier to have a large hole and then the alignment came ŵhen screwing into the clip...
Jerry
