- First Name
- Heman
- Oct 15, 2023
- Houston, Texas
- 2023 XLT Maverick
- Engine
- 2.0L EcoBoost
And no DI, turbocharger.I want a carburetor![]()
The new Echoboost has eight injectors to eliminate carbon build up. When or if we see carbon build up there's a recommended service procedure decarbon that's usually takes thirty minutes.It is supposed to help with carbon buildup on intake valves.
Separates oil and air from the mist coming from pcv . Oil drains into can and cleaner air to intake track to burn.
The recommended procedure is removing the intake and walnut blasting the back of the valves.The new Echoboost has eight injectors to eliminate carbon build up. When or if we see carbon build up there's a recommended service procedure decarbon that's usually takes thirty minutes.
