No cruise after TS update
RONR11
Ron
Hartsville SC
2019 Ranger/Maverick
Anyone else have this issue? Bad part XL
Added so I’m wondering if Ford will not
Also Radio has a scan now to link other
Music? Txs
Deleted member 7089
Guest
The recall flashed over the cruise control changes that you or someone else made to get it to work. That part with Forscan needs to be redone.
Is this a documented thing elsewhere? First I hear of it.
EDIT: First I hear of an update/recall erasing a Forscan mod.
Robert C
Robert
2001 Ranger
The don't document things that get messed up because YOU messed with it.
If the cruise control that you put in on your 22 gets messed up with a Ford software update they aren't going to tell you your hack may not work anymore.
bgn
WA
Deleted member 7089
Guest
They don't document things that get messed up because YOU messed with it.
Who's they? I meant here or on Reddit.
Deleted member 7089
Guest
I have a basic XL. Just had recall done and now no cruise. Knowing XL no CC. I had a guy for scan. And need to got the codes again
Looks like you are the first to report this. Let us know if you get CC back.
I was aware of the Forscan mod, but not heard about them getting erased by an update/recall. Similar threads at the bottom of this page also coming up empty.
Duh... Some of the updates correct many items whatever needs to be changed. If dealer had made the changes and posted them to your vin# they would most likely stick or be corrected free of charge. It may be that the update did not directly erase your changes but something else is not working they same way as before. In any case it's time to rehack your truck.
Flyangler
Sarah
Minnesota
2022 Ford Maverick Hybrid XL
We installed cruise on my ‘22 with OEM buttons on the steering wheel and Forscan.
After the 12V harness Customer Satisfaction work was done, the dealer reset all to factory settings. Cruise did not then work, because the truck did not come with cruise. So, we are now prepared to re-program with Forscan after every service.
Deleted member 7089
Guest
Duh... I'm not the OP.
RONR11
Ron
Hartsville SC
Anybody got the codes to reinstall hybrid basicXL txs. And can it be done with Ford equipment?
