No codes at dealer
Bigberm
Randy
canada
2024 Maverick XLT
Took the Mav in to have Ford checkout the codes that showed up in the BCM and check battery but they say battery is fine and no codes.I ve had to boost the truck 4 times and did have the info screen go blank and then the high beams wouldn't work but a key reset fixed it and that happened twice.Anyone esle have this problem? 2024 EB
Were you able to show the service department a picture of the codes?
Bigberm
Bigberm
Randy
canada
2024 Maverick XLT
no,not yet but will bring my print out.They won't care about that though,it's only what they find
RR - All the way
GA
As an EB owner I would ask that you go outside and check if your truck really is an EB. This sounds like a hybrid problem. May be this is contagious.... have you parked next to a hybrid lately?? Seriously hope you get this figured out. Please let us know the final outcome. Thanks!
Do you or even an unknown family member perhaps have the key to Accessory mode often for radio, or doors open/closed a lot with light always going on?
Or powerport used with USB device that keeps pulling power for the upwards of 75 min?
Well - that time limit should be much shorter now if an actual low voltage problem.
Bigberm
Bigberm
Randy
canada
2024 Maverick XLT
Well got the truck back from Dealer and they say no codes showed up and they said all B codes,U codes are loss connections but all B codes are the BCM codes,I guess I'm on my own,lol.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
Took the Mav in to have Ford checkout the codes that showed up in the BCM and check battery but they say battery is fine and no codes.I ve had to boost the the truck 4 times and did have the info screen blank and then the high beams wouldn't work but a key reset fixed it and that happened twice.Anyone esle have this problem? 2024 EB
Sounds like a frame short..
But, a key reset fixes it??
?Software issue, telling the computer something else...
Jerry
Bigberm
Bigberm
Randy
canada
2024 Maverick XLT
A key reset fixed that problem but have 15 codes in the BCM
Robot-Wrangler
Kentucky
Continue documenting codes and faults. Report to NHTSA. Remove the battery and have it fully tested. Clean the battery terminals and use battery terminal spray. Good luck.
I've had to charge or jump start my Maverick Lariat hybrid AWD three times. I carry a jump pack and a battery charger.
I work 12hr nights and I program the Ford Pass app to remotely start the truck twice through the night and don't have issues any more. I only need this when it goes below freezing.
Finnster
N. E. Wisconsin
Chevy, Kia, and a 2025 Maverick Hybrid 4K Tow
Try a different dealer next time!
boxster03
michael
santa fe NM
2023 Maverick XL Area 51
you mean "Ford DEALERSHIP" nothing to do with Ford Motor Company
