Newbie needs help with a borderline towing situation
Tiger Dude
Skip
Louisiana USA
2023 XL
The reason you will get varying info on WDHs on the internet is because everyone with a hitch has an opinion, and being informed isn't a requirement for having one. Also, unibody trucks aren't very common, so the sample size is small. The WDH would not mount to the frame (because you don't have one) and so you will be choosing a random point to mount to and hoping you don't bend up the vehicle with forces it wasn't designed for. You're expecting some dude at some shop to do it "right." People do all kind of things to unibody vehicles (Jeep Cherokees XJs for example), but don't expect help from Ford if you break yours doing things outside the box.
Mavster Mechanic
Hybrid
^The guy above is worried about it clearly, but has no idea what he is talking about.
The WDH goes into exactly the same factory slot as any other. There is no "picking of a random point to mount to" whatsoever. There is nothing added to your vehicle.
The extra bits go on the trailer.
It only changes the force vectors, direction of force if you will. But it does not change much at all.
Instead of having a downward and backward pull on your hitch with a simple one, a WDH will put force upwards via spring steel and still has the same backward pull on your hitch.
For a Maverick it doesn't do a lot. For good or bad. Which is probably why you don't need one.
Johnkn
MD
It doesn't do a lot. For good or bad. Which is probably why you don't need one.
A WDH can effectively more than double the rating on most of Ford's (and other OEMs) tow capacities,. When looking at most OEM truck and large SUV receiver hitches you'll see ratings for both weight carrying and weight distribution hitches on stickers from the factory, but not on the 3 Mavericks I've owned.
It requires a special WDH ball mount to accept the bars (and sway control if used) which goes in the truck's receiver hitch, as well as other pieces (spring bars, spring bar mounts attached to the trailer tongue, drop chains or bars, etc.)
[OP] I've attached a F-150 Ford factory tow guide as well as a Maverick town guide for reference... With the Maverick 4k rating, you're looking at a 4000lb loaded trailer with 10% (400lbs) of weight on the ball for proper handling. The actual calculation is that weight on the ball is subtracted from the trailer weight, (ie: a 4400 trailer with 400lbs on the ball = a 4000lb towed trailer).
Note there is no reference in the Maverick guide for Weight Distribution Hitches.
As to their effectiveness, The F-150 guide as well as Super Duties, Expeditions, etc. as state " Do not exceed trailer weight of 5,000 lbs. when towing without a weight-distribution system" even though in the F-150 for example, it's rated to tow in excess of 13,000 lbs when properly equipped. Etrailer.com caries several WDH systems rated for 4000/400lbs tongue weight..
I have experience towing up to 14k trailers with and without WDH, I have no experience towing with a unibody platform but would ''speculate' if the vehicles structure is sound enough to take the towing and weight loads, it would work in the opposite direction effectively moving weight forward to the truck's front tires...
#1, make certain you have a good trailer brake controller that's properly adjusted, and ~10% of the towed weight on the hitch ball for sway control.
Good luck
2025-Ford-F150-Towing-Guide-1 (1).pdf
2026-Ford-Maverick-Towing-Guide.pdf.pdf
good luck all
Mavster Mechanic
Hybrid
"SUPER DUTY" the Maverick is not!
LOL
A WDH DOES NOT increase the towing ability of you, or your vehicle.
Some manufacturers derate their trucks without it.
So maybe you are looking at the glass as half-empty and I'm looking at it as half-full.
But bottom line: the 4k Maverick is rated for 4,000 lbs with and without a WDH.
If you like it, use it.
If you don't, don't.
I've towed 3200 lbs 10,000+ miles without one. And a couple hundred with one ON MY MAVERICK and I could tell no difference.
In theory a WDH would help the FWD and FWD biased vehicles.
However, on a scale, my front to rear axle weights were pretty nice without one. Almost equal front and rear (with an empty truck always being lighter in the rear and a fully payloaded one being much heavier in the rear).
35 years of towing tells me 10% trailer weight on the ball is minimum. 15% is desired and more stable. 15% and no WDH is a winning combo for me.
Johnkn
MD
LOL
Again, The OEM tow ratings for virtually all new trucks (sans unibody Mavericks, etc). are predicated on the use of weight carrying or weight distribution hitches (or gooseneck/etc.). The info is in their guides and additional rating capacity usually present on the tag on the receiver hitches showing the receivers WC/WD ratings.
Read what I wrote from the Ford Towing Guides on F-series, Super Duties, Expeditions, etc. which all reference weight distribution hitches (while the Maverick Towing Guide makes no reference to the WDH).
Max towing Rating with load carrying is perhaps 1/2 of that of their WDH ratings
As an example, when properly equipped, the F150 is Ford rated to tow >13,000 lbs, but the Ford caviat in the Guides is:
• Do not exceed trailer weight of 5,000 lbs. when towing without a weight-distribution system
Ford derates the towing capacity by 60% when not using a WDH in that example. My comment was in reference to your comment in post 17 above.
But it (WDH) does not change much at all.
and
It
(WDH) doesn't do a lot. For good or bad. Which is probably why you don't need one.
I'm sure you tow your stuff just fine.
I've been fortunate towing mine for the last 55 years...
I wouldn't hesitate to tow 4k/400TW all day long as-is with a 4k-rated Maverick (with reasonable frontal area, and appropriate gross vehicle weight).
It's all good :thumbsup: :thumbsup:
Good luck OP!!
[edit] here's an off topic fun pic when I towed my 2nd hybrid Maverick home (with my TRX off all things, LOL).
Ford Maverick Newbie needs help with a borderline towing situation 3c5TVU
Ford Maverick Newbie needs help with a borderline towing situation SoXKqt
