Need help with locating drain holes or plugs for tonneau cover
Mightybeast
Adam
Oklahoma
Maverick hybrid
Please post pictures of drain holes or location where they are.
RTP-Mav
Cody
OH
2016 Ford Transit Connect
Following. Struggling with where I should put my drainage holes on my drop-in bed liner. Have a Bakflip MX4 hard top installed.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
The cut outs are marked on the backside of the liner. You'll need to take the side pieces of the liner off to find them.
Hot Runr Guy
West Chicago, IL
I just installed my Bakflip MX4/Elevate TS rails this morning. I used a hole saw to remove the center of the grommet shown, and fed the hose thru there.
HRG
Ford Maverick Need help with locating drain holes or plugs for tonneau cover IMG_0992.JPG
Johnkn
MD
^^, or run them in the gaps in the very front bottom corners of the bed. That’s where mine are so the tubes are not potentially in the way of anything loaded in the bed.
Tybrus
New Brunswick
Nissan Kicks
What if you order the drop in liner from the factory. Do they pre drill the drainage holes?
Tybrus
New Brunswick
Nissan Kicks
I suspect that means I'm going to have to remove the liner to make the cuts.
