MY24 order questions
bobbill
Baton Rouge
2013 Ram
I ordered a MY23 XLT hybrid with the hitch, floor liners and the inside 400W behind console nothing else. My dealer entered a MY24 order for the same options knowing can’t get the 400W as a stand alone. I then requested my dealer to change my MY24 order to a XL EcoBoost with the same 2 options. Can this change be done? My dealer tells me to go online and enter my order as I want it and send them the pdf so they can make the changes. Is this the way to do it and will they keep my MY23 order number on my MY24 order for my private offer? Not completely trusting them. Any help is appreciated.
OleFordGuy
My limited understanding is (this may or may not be accurate) the MY23 & MY24 order numbers need to match along with the covp information that needs resubmitted with the MY24 order. Hopefully others can respond. Think there's been other threads related to the subject. This one may help you to some degree: https://www.mavericktruckclub.com/forum/threads/private-offers-for-the-2024.34411/#post-623018
You may want to message Tim the video guy or one of the other members that work at dealerships such as KevCuRaoi
Fibrepunk
2023 Ford Maverick XLT Hybrid
If I recall, for 2024 Mavericks, the 400W inverter behind the center console is only available under the Lariat trim, regardless if you pick Hybrid or EcoBoost.
commadorebob
I think he wants you to use the build tool because it will ensure a compatible order. Do what he said. Just make sure the resulting order number matches your MY23 order and that your last name is the same. Should work just fine when Ford does the rollover.
Old Man
Nebraska
2023 Lariat
That's how my dealer did my pre-order, built in the builder then printed it off for my records and theirs. Changes can be made to the 2024 order like mentioned keeping all order number, etc. the same.
Bob - you have the exact same tag lines as me except mine is black and different dates.
It's not available as an individual option for any trim. The XLT Luxury Package and Lariat include the inverter with outlets in the cab and the bed.
commadorebob
It's pretty in blue. Really stands out
LSchicago
Lloyd
IL
Yes, 400W outlet and Sliding rear window as stand alones were deleted for 2024.
