My linex sprayin bedliner is messed up
Maarijk
Maarij
Ohio
Ford Maverick Tremor
Ford Maverick My linex sprayin bedliner is messed up IMG_0369
I noticed that they sprayed in the rubber inserts which is annoying. I also want to know if they covered any holes for wiring. And should I try to screw something in to make in the holes to make sure it works? I am very disappointed and now I have to make another trip. What should I say to my dealer to get them to fix this?
Ford Maverick My linex sprayin bedliner is messed up IMG_0368
Ford Maverick My linex sprayin bedliner is messed up IMG_0367
Ford Maverick My linex sprayin bedliner is messed up IMG_0366
Ford Maverick My linex sprayin bedliner is messed up IMG_0365
Ford Maverick My linex sprayin bedliner is messed up IMG_0364
Ford Maverick My linex sprayin bedliner is messed up IMG_0363
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
Irritating I know...went thru the same thing...Took all my hardware in to them asked them to install and they did...at no charge. I suggested before hand that they put golf tees in the bolt holes and they thought that was silly...
Stang89
Kevin
1989 Mustang, 2014 CMax
I had to use a tap to clean out the two 8mm holes for the bed rail bolts, the front 6mm hole didn’t get as much bed liner in it and didn’t need to be cleaned.
05FordGT
Chester County, Pennsylvania
2019 Fusion Energi(lease), 2006 Mustang GT
This looks like amateur hour at the Line-X shop! 🤦🏻‍♂️ I sold Fords for 23 years and I was the only one who did a decent business selling spray in liners. Local shop not really close to us, but their quality was TOP NOTCH! They always stood by their work. They removed EVERY AND ALL bolts, screws, plugs from the bed and sealed every hole so no product would get in. All those years I had 1 issue, and it was their paint gun malfunctioned, so they kept the truck an extra day. This shop here did a lazy job. If it was my truck, I'd be pissed!
hurrah
Hartville, MO 65667
2019 Ford Ranger 2012 Ford F250 6.7 2015 Ford XL
Unfortunately you had a crappy line-x dealer. My dealer removed everything and replaced after the liner was sprayed in. Way more professional that my previous experience with Rhino in previous trucks. I was more than impressed with their attention to detail.
Goldie
Franklin,Pa
Mavrick XLT 2022
FamousAmos
GAB
Maryland
2022 Maverick Hybrid XL
Apparently, all Line-X franchises are not alike. The local Line-X shop closest to my dealer was booked up, so my dealer went to the next-closest Line-X shop about 10 miles away. They sprayed over everything, including bolts and screws that they shouldn't have. Not knowing this, I just went to my local Line-X shop to clean out the two Torx-type screws so that I could install a storage compartment. He was very cooperative. He said that he always covers bolts and bolt holes before spraying, which should have been done on my torx screws. I don't know how much driving it would require, but if you get no satisfaction from your Line-X shop, YOU MIGHT TRY ANOTHER LINE-X SHOP. Good luck.
Charles T.
Charles T.
Metro Atlanta
2017 Edge. 2025 Maverick Lariat
Mine was sprayed by my dealer; 100% satisfied.
gwrace14651
TX
Agreed check the reviews for your line-x dealer before having them spray it. Some are obviously better than others. My son had his done here in town and they did an awesome job. I just opted for the Lariat which now includes the factory SIBL.
B2000
midwest
B2000
I met with my LineX guy when I made my appointment and told him I wanted everything taken off before spraying. They ended up having my truck for over 4 hours but I would rather wait then rush it. Plus I got a ride to go eat from a friend. So far so good.
MaverickSVT
Ohio
2000 Ford Contour SVT
those rubber like grommets.
Does it really matter? What are they for?
Ford Maverick My linex sprayin bedliner is messed up IMG_0360
Ford Maverick My linex sprayin bedliner is messed up IMG_0361
Ford Maverick My linex sprayin bedliner is messed up IMG_0362
Ford Maverick My linex sprayin bedliner is messed up IMG_0359
OneHappyTremor
Darrin
Northern California
2023 Tremor Lariat
Well, it could’ve been worse - at least they didn’t coat over the tie-downs or torx screws. Just replace the rubber grommets, and chase any threads if those were sprayed.
Ford Maverick My linex sprayin bedliner is messed up 51E3D84A-8C5C-41DA-AC0F-D0B81E12CCE9
