Mirror Dashcam Distracting
hpz937
MN
2026 Maverick XL
I just installed a Wolfbox G900 Pro last night, I got it because I felt the factory mirror is too small and I wanted a dashcam so this would fit both needs. I've only driven twice since but I find it very distracting, the wide angle of the camera makes it even worse with the constant motion I wouldn't normally see. That and I feel like I can't judge distance to cars behind me, the camera is so wide that cars not far back from me are tiny little specs on the screen.
Anyone else feel this way? will I get used to it or should I just return it?
Dave O
New Smyrna Beach Florida
Those are valid concerns I have the same WolfBox installed and i absolutely love it - yes it does takes some getting use to and you should check your side mirrors to verify the distance of the vehicles behind you but the benefits in my opinion outweigh the bad
rick52
Rick
2026 Maverick
There's a good reason factory backup cameras don't work while in a forward motion.
HanksGT
Hank
Phoenix, AZ
2025 Maverick XLT lux
My dashcam arrives tonight. I didn't think about a screen on/off switch. I want the recording, not as much the live view. We'll see tonight, otherwise an index card taped in place will work for me. Thanks for the heads up.
hpz937
hpz937
MN
2026 Maverick XL
I got the OEM mount kit yesterday, I would say it's an improvement. with the mount that comes with the g900 pro, that straps to the stock mirror, it has to be offset quite a bit to the left to clear the camera. Now it's about 2 inches to the right and 2 inches back and is much less in my line of sight. I'm gonna give it a week or so and see how it goes.
Marty
2026 Ford Maverick Tremor
Op says, “ because I felt the factory mirror is too small.”
I had my wife walk around the Mav, while I was parked.
No blind spots,
Stock center mirror, I’m tall so the stock mirror is up by as high as possible. This helps when looking all around.
I did have to turn my head a bit and lean up just a little. Not an issue.
My Factory 360 cameras work flawlessly when I’m in reverse or under 6 mph going forward.
Or at any speed in the ‘Off Road Mode’
It’s a Tremor thing :’P
Randorita
Randy
Mississippi
2021 Toyota RAV4, 2025 Maverick Lariat
I have the rear view camara option on my RAV3 and ended up not liking it. It doesn't have enough fps to be smooth and is too bright in the daytime.
F150 2.7 TT user
Kenneth
SE WI
2026 Maverick Tremor, 2017 F150 XL 2.7
I have a WB850 in our Tremor. The rear camera is mounted top rear window inside the cab. Mounted on the WB universal mount and hard wired. I use the switch on the mirror bottom to disable the display, this does not disable the cameras it will keep recording with the display off.
Jman79
North East, USA
Honda Odessey, Ford Maverick 🤞MY24
I installed a similar pelsee, but I did so next to my rear view mirror above the A-Line. It's great to offset the normal rearview but I wouldn't like to use it instead of. Also I find even at its dimist setting it affects night vision, so I turn the screen off most nights.
Great to view cargo while driving as it can adjust down and up for a full bed view.
hpz937
hpz937
MN
2026 Maverick XL
I hadn't really thought about that. I haven't driven at night yet..
wakkawakka22
Branden
Tulsa, OK
2026 Ford Maverick Lariat Hybrid AWD
No blind spots,
How big is your wife though? 😂💕
Jman79
North East, USA
Yeah, my original hope was that the lowlight capabilities of the camera (far exaggerated by marketing) would make it a worthy addition to night driving dark roads. However, it's not that good and the negative on my own night vision is indeed a factor. I rarely ever drive with it on at night anymore.
I'm headed to run an errand in 30 and will post pic of my dual setup for those who might be interested in the idea.
F150 2.7 TT user
Kenneth
SE WI
The WB850 is nowhere as good at nite as the Rexing M3 mirror cam in my F150. I like the Rexing for that, but the Wolfbox does produce better video.
Jman79
North East, USA
As promised ... Best of both worlds IMO.
Ford Maverick Mirror Dashcam Distracting 1000022458
Disregard the wire routing I told myself I'd take care of a week after POC mounting and it's now been over a year 😂
