Scott Asheville
Scott
Asheville, NC
I have the same tires, having been forced by premature wear to replace the OEM Continentals at 28,000 miles. The Michelins don't squeal going around the cloverleaf at moderate speed, and they just plain feel better. Tread depth is awesome. Projected tread life is also promising.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
Have you been watching your MPG closely enough to have a feeling for how the Michelins fare on that front? I've been having fun trying to see what I can get, and only beat 50 MPG for a full tank (>500 mi) once. Yes, that was "indicated". Actual MPG was about 4.5% lower.
rclee
Rob
Dayton Ohio
Going with that size, is your speedometer off? If so, is it faster than indicated or slower?
Ozarkbeard
You can easily change the displayed estimate to more closely match your calculated MPG, using the steering wheel buttons to access ET mode. https://www.mavericktruckclub.com/forum/threads/have-you-calibrated-your-mpg-display.33213/
agmonaco
Tony
Pittsburgh
2024 Ford Maverick Hybrid
I have the Michelin Primacy All Season tires with my new Lariat. Man the revues are terrible on those tires. Interior has foam that detaches, terrible performance in snow, Side wall blow outs. 60% had bad ratings. What happened to Michelin?
I went through 2 Kansas winters them no issues.
the primacy a/s is made for fuel economy. it isn't intended to be the same kind of tire as a defender or crossclimate.
agmonaco
Tony
Pittsburgh
Tha
I went through 2 winters them no issues.
Thank you for that report.
Deleted member 7089
Guest
Does that video work for anyone? I've got a gray box with "No video with supported format and MIME type found".
zach57x
FL
2022 Maverick XLT
Should be slower but they’re not that big enough to make a difference imp
huh, I get that error on my home pc also, but it could be due to firefox and/or ghostery plugin.
I can see the embedded video fine on my android smartphone.
Jackfer
Jack
Central NJ
2022 maverick
I see everyone concerned with speedo accuracy and mpg. There's no need to consider any.of that. One of the stock sizes is a 235/65/17 you can enter it in through forscan and your truck will adjust itself. It is the largest tire option.
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
This makes a lot of sense.
One of the best all-around tires for 95% of your on-road driving and they still work fine for the 5% off-road.
vs the folks that always suggest AT tires 'just in case' you go off a paved road once.
