MBRP catback exhaust system installed
Don's Maverick XL
Donald
MISHAWAKA
2023 Toyota Corolla hatchback SE
Probably my last mod on my 2024 ford maverick xl awd ecobost. Just replaced my stock exhaust system with MBRP cat back exhaust system uses all original rubber hanging mounts just have to cut the stock exhaust pipe 16 1/4 inches from the back weld on the stock catalytic converter. To cut pipe I got a exhaust pipe cutter from harbor fright $26 made job so much easier than saws all. Then it's just putting the new exhaust together. (Hint) make sure all ends of new system go together before crawling under truck and find out the pipe was smashed in shipping or whenever. But after getting that bent back out it went great. Doesn't sound much louder but I can tell the motor runs smoother and excellarates much faster. We'll worth $405.00 free shipping and no tax. Anyway I love it. Here are a few pictures
Ford Maverick MBRP catback exhaust system installed 20241019_104259
Ford Maverick MBRP catback exhaust system installed 20241019_104347
Ford Maverick MBRP catback exhaust system installed 20241019_104354
Ford Maverick MBRP catback exhaust system installed 20241019_104325
Ford Maverick MBRP catback exhaust system installed 20241019_104411
Baloo
Michael
Indianapolis Indiana
One of the first things I did to mine was the cat back from MBRP.
I did change out the tip when I installed it.
One of the first things I did to my 22 was the MBRP Stainless Steel catback. Loved it everyday since install.
I did change out the tip, ordered it same time as I did the kit.
Ford Maverick MBRP catback exhaust system installed 322256152_688602002978773_3516842534244268679_n
Superg0
2024 XLT FX4 Azure Gray
I bought that Harbor freight exhaust cutter as well. For a tool that I don’t use often but don’t have one, Harbor Freight is a winner for me.
tciotti2003
Tony
Arizona
2022 Lariat
Question to you gentlemen. What does the catback gain you? I know what it supposed to do workibg along side cold air intake and tuning but working by itself. Asking cause I too am considering installing one. Thanks ahead of time
Baloo
Michael
It is less restricted so maybe a little gain.
I have ran MBRP exhaust dating back to 1999. Never had an issue with their products. It is more of a deeper sound than other exhausts I have heard. It isn't tinny, or Honda Fart can sounding, just deep.
Superg0
Catback systems are sometimes less restrictive so better flow. You are still going from 2 1/4” to 3” so unless you delete catalytic you aren’t gaining a lot of flow. Sound change more than anything.
Mdavis
Michael
2024 Maverick XLT
What wheels are on your truck? They look awesome. Could you possibly post a side view, and specs? I would appreciate it!!!
Don's Maverick XL
Donald
MISHAWAKA
Sure here are a few pictures I got them at discount tire
Ford Maverick MBRP catback exhaust system installed 20240508_122356
Ford Maverick MBRP catback exhaust system installed 20240508_141554
Ford Maverick MBRP catback exhaust system installed 20240508_141630
  • Like
Reactions: Guv
Don's Maverick XL
Donald
MISHAWAKA
They
They are same size that came on truck they look like chrome but it's actually paint called virtual chrome really like that doesn't rust or oxidize but can chip if hit hard enough. And they shine like chrome. I have a fourm that shows all my mods. I have about $5,000.00 in mods already still have nurf bars to put on then I think I am done. Here are most recent pictures
Ford Maverick MBRP catback exhaust system installed 20241004_150522
Ford Maverick MBRP catback exhaust system installed 20241004_150654
Ford Maverick MBRP catback exhaust system installed 20241004_145823
Ford Maverick MBRP catback exhaust system installed 20241004_150709
Ford Maverick MBRP catback exhaust system installed 20241004_150635
Ford Maverick MBRP catback exhaust system installed 20241004_150513
Ford Maverick MBRP catback exhaust system installed 20241004_150702
Don's Maverick XL
Donald
MISHAWAKA
From what I have read it just reduces back pressure and let's the turbo flow better and sounds cool. Doesn't require any tuning and don't like cold air induction because it could require a tune and I don't want to do all that. But I will say my truck runs alot smoother after I put the catback exhaust system on
Don's Maverick XL
Donald
MISHAWAKA
Agreed love the sound
tciotti2003
Tony
Arizona
2022 Lariat
Thanks for your response
tciotti2003
Tony
Arizona
2022 Lariat
Marty
2026 Ford Maverick Tremor
In the old days when we put Hooker Headers on our V-8's, the 302 was a fav.
We had to wrap the headers in an Asbestos base heat shield to help hold in heat for the exhaust valves. If they got cold due to the better air flow they no longer sealed up against the head as well. This, 'Blow by' burned valves and cracked pistons.
Now you put on better flowing exhaust or drop in a K&N Air filter the air gate closes up some or the Injectors adjust according to the fuel control system. But The Turbo now has access to faster air flow/quicker spin up than before, even a little means something right !
Earl313
Earl
Grosse Pointe Park Mi
BMWZ3 Ford Fusion Nissan Altima On order xlt lux
I have modified other 4 cylinder cars with cat backs, milled and ported heads, cams, ported manifolds and headers and chips with good success. This eco boost is by far the easiest to get improved performance.
Magna Flow cat back, AFE high Flo intake filter and sport mode equals a fun rides.
Now thinking of suspension changes to increase the fun.
