Maxzina-Maverick Truck Bed Side Rail Available Now
Maxzina
Diamond Sponsor
New Jersey
Hello MTC Owners,
Today,truck bed side rail (a pair) has arrived at Amazon.
They are made from high-quality aluminum alloy, the truck bed tie down system is lightweight yet exceptionally sturdy, offering the perfect balance of strength and resistance. The aluminum alloy construction also provides anti-rust properties, making it suitable for long-term outdoor use.
The L-track Tie down system features adjustable tie-down points, including tie-down anchors and L-track bolts, which can be fixed on the tracks to accommodate various cargo sizes and shapes. The spring mechanism on the tie-down anchors prevents them from sliding on the tracks, ensuring cargo stays in place during transit. Additionally, the ability to hook bungee cords onto the hooks or wrap straps around the loops provides multiple securing options for different types of cargo.
The aluminum alloy truck bed tracks are designed for easy installation, using original holes and requiring no complex tools or drilling. Once installed, the cargo tracks provide a clean appearance and are compatible with other accessories, adding further practicality to your cargo management solutions.
🔔PS:
🔎If your truck is equipped with a factory DIBL (drop-in bed liner), please make sure to cut and reserve the original holes for installation.
🔎If your truck is not equipped with a factory DIBL (drop-in bed liner), please use original holes for installation.
Original Price:$129.99
Now Price:$98.79
👉Shopping link:
https://www.amazon.com/promocode/A2YD697FDYR38B
promocode"207GB3K5"
The link will ends at 2025-1-21 23:59
Prepare stunning mods for your Christmas!!!
Hope you enjoy holidays!🥳🥳🥳
Let's join group to discuss amazing modifications for Maverick and enjoy unique discounts.
ofcbc
Crossville, AL, United States
2024 Maverick XLT
Has anybody had any luck putting something like this a truck with a drop in bed liner? I mean I figure it would work. Honestly, I'm afraid of drilling the holes. I don't want to miss or drill too deep and mess something up.
Maverickman74
Shane
Maui HI
Looks good, you should figure out a way to mount those self retractable ratchet straps to it. I added them to my Ford factory rails in a fixed position and they are a game changer for me. I can only imagine how awesome they would be if you could move their position.
Maxzina
Maxzina
Diamond Sponsor
New Jersey
This no drill.Use original holes.Reduce the risk of damaging truck parts.
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Great work!
AbnRgr
Athens, AL
Porsche 944NA, Mazda Miata, PT Cruiser Conv.
I had to add rails to my ’24 XLT when I installed Mabett’s bed divider. Unfortunately, Ford provided a DIBL, with the luxury option with no means to substitute a SIBL. That earned more than a few four letter words addressed to Ford from me. Installation of the rails required that I dismantle the DIBL and open up multiple bolt hole locations and those at the tailgate for the 12V pigtail. I wouldn’t even think about drilling without taking the DIBL apart The markings on the backside of the DIBL sides for drilling were faint if visible at all. I ended up having to measure and mark the distance from one bolt hole to the next. Let’s say I wasn’t always accurate. I was left with more holes than needed. I was fortunate that the installed rail covers over my mistakes. Another issue is that the DIBL is not a second skin on the metal bed sides. It is a very loose fit with significant space in some locations between the DIBL and the truck sides. I needed to make a stop at a big box store to find longer metric bolts to complete the installation. It is definitely doable, but more of a pain than should be required.
AbnRgr
Athens, AL
While your product is designed to make use of the Maverick’s OEM bolt hole anchor points, that does not mean there is no drilling. Those with a factory DIBL will have to drill holes in the liner corresponding to the bolt hole locations on the truck bed sides.
AbnRgr
Athens, AL
I agree. I understand Maxzina hopes to introduce retractable tie down straps for the Maverick soon. Sight unseen, I have an idea of how I will be able to mount a pair to my side rails and slide and lock them anywhere along the length of the rail. If successful, I’ll post how I accomplished the mod.
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Looking forward!
Maxzina
Maxzina
Diamond Sponsor
New Jersey
While your product is designed to make use of the Maverick’s OEM bolt hole anchor points, that does not mean there is no drilling. Those with a factory DIBL will have to drill hoe in the liner corresponding to the bolt hole locations on the truck bed sides.
Ok.Understand!Thanks for the explanation.It is very usful!We will include it in our description. ;)
Maverick2112
2025 xl hybrid.
Yes, I have done this. You need to remove the side panels. I put the holes in before I installed it. I can’t remember, but some of them are marked on the other side. I used a spade drill and drilled a 1” hole which was covered when the track was installed.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
I installed L-Track in my bed (no liner) and really like it, BUT I had to make both 6 mm & 8 mm transfer punches (screw shank with pointy cone end) to precisely locate the mounting holes in the rails so flat-head machine screws would sit flush with the inner surface of the rail. If they don't, then an L-track anchor will not be able to slide past that point. It's not all THAT critical, but annoying. The threaded holes in my bed were not precisely located (varied a few mm) so I have strong doubts that pre-drilled rail holes will line up well enough with them to allow the screws to seat properly. If these rails were made with extra space inside (to allow pan head screws), this would no longer be an issue. Note that L-track anchors from different vendors may occasionally have issues on a different vendor's track.
Maverick2112
2025 xl hybrid.
I made up 10 or 12 sets of these for Mavericks and tried them on 3 different trucks. I did find slight variances and on the production models and I abandoned the countersink screws because of this and went with a slotted hole and shallow head cap screws. A countersunk hole and matching screw only works well when perfectly aligned. Also, I was concerned about the thickness of the metal at the back of the track when countersinking for the screws, as it got quite thin.
Maxzina
Maxzina
Diamond Sponsor
New Jersey
Very detailed description!
