- First Name
- Daniel
- Oct 13, 2023
- Mechanicsville, VA
- Ford Ranger XLT
- Engine
- 2.0L EcoBoost
Just FYI.
If it was not connected to some airport WiFi network - there was nothing happening that having that setting enabled could possibly do.
The System logs when you are connected to a wifi network, and if you are then it seems to connect once a day or less frequently to see if an infotainment center update exists.
At this point I'm doubting the Lariat has many updates either, so it would be less than a 1 minute and just bytes of data to check.
Because that's the only firmware that option deals with, and the only way to use it.
But I'm betting you weren't connected to WiFi anyway - so a moot point.
Was more likely the TCU referenced many times in this thread.
If you used Fordpass you should have received notice a notice it was being disabled by the Deep sleep message.
If you never got one then you probably had the issue of the infrequent battery drain that wiped it out faster before it could report it was going to Deep sleep.
Or the ATT network was about useless in it's location and no data got out - but perhaps the attempt to use it caused the drain.
