Maverick's first paint scratch: From its wiper blades
Terry Barner
Rolla, Missouri
2024 Ford Maverick Hybrid XL
Here is your opportunity to learn from my rookie Maverick owner mistake.
For those of us who live where freezing rain and sleet are a winter possibility, smart motorists prop their wipers off the windshield in the upright, locked position before a freezing rain or snow event. This prevents the wipers' rubber from peeling off if they are frozen to the window glass when the wipers are activated once the precipitation ends and the thermometer bottoms out.
Yesterday, I propped the wiper blades up as I left the truck parked at work outside during some sleet. Ten hours later, I remote-started the truck, not realizing that the wipers might go back-and-forth. Fortunately, the motor ran without the wipers being activated. An important note is that the wipers will clear the back of the truck's hood when the wipers are in the upright position, but will definitely scrape the hood's paint if the wipers are left up and the wiper arm cycles back to its closed position. This is precisely what happened when I went in and turned the key to the start position to start the seat heater and drive the truck. All of a sudden, all I could hear was the wiper arms retracting and grinding against the hood lip. Scratch!
Of course, I couldn't see this calamity because I had wrapped a plastic windshield cover over the windshield to peel off the ice that had accumulated on the windshield. Once I got home, I got a good close-up look at those first two paint scratches.
So the moral is, if you prop your wipers up to prevent ice accumulation on them, make sure you retract the wipers before you turn the ignition key. Otherwise, the wipers will smack the hood.
Yes, this morning I got out the truck's Ford touch-up paint and dabbed these two scars on my truck. Lesson learned.
Ford Maverick Maverick's first paint scratch: From its wiper blades scratch_wide
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
Just hopped on to search for another unrelated wiper issue and found this ... what a bummer ... but thanks for the FYI.
Milwrdfan
Scott
Iowa
25 Lariat Hybrid
For those of us that live in cold climates where putting up wipers is normal procedure during winter weather, I wonder if putting on a strip of door guard (that's usually used for protecting the edge of a door against door dings) would work to put on the edge of the hood so if one does forget, it'll hit the guard strip and not the hood edge itself?
commadorebob
Bummer. Lessons learned.
rlhdweman
Random Lake Wisconsin
I have been driving in a winter climate since 1979 & in that time I have never once done this with my wipers, & honestly, I have only seen people doing this the last several years, it is a bad idea, a good wiper slap against a cold windshield could also cause a crack. People please stop doing this, if the wipers are that frozen against a windshield use a can of spray deicer or warm up vehicle with the defrost on high.
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
That is an awesome idea. I have quite a bit left over from doing all my doors, now I know what to do with it!
Dnel29
Regina, SK, Canada
2025 Ford Maverick Lariat EcoBoost
I dunno...doesn't seem so smart anymore haha but that does suck! I had this happen once before with automatic wipers on my old car, but it didn't scratch anything.
710-oil-614
Cal
2025 Hybrid AWD Lariat
A good wiper slap against a cold windshield WILL cause a significant crack…..ask me how I know? 😂
Like you, I’ve never raised my wipers like this and I’ve lived in the North for most of my life.
Bob The Builder
Butch
Vermont
Exactly. Same here. Both my vehicles have the wiper deicer in the windshield to help matters.
Deleted member 5352
Guest
I remember something similar happening on our Bronco Sport. I propped them up manually, which is a big no-no, and when I turned on the accessory mode, the wipers slammed back on the windshield and the right arm chipped the paint on the edge of the hood.
I learned later on this forum to put it on accessory mode, turn on the wipers and immediately turn the car off once they're are at the center of the windshield. This way, I can lift them up safely without manually yanking them from their resting position. No wear and tear on the motor anymore.
That's a bad design. I know German cars are notorious for that as well. I'm sure it's for efficiency or better aesthetics but it makes for a pain in the ass for maintenance. All we want to do is prop them up whenever. It's just an extra step for no reason.
Nipperchipper
lance
Rosetown
2008 Escape 2023 Maverick Lariat
Been There
Done That
