Pretty new, I believe it came on market in 2020Does anyone know if this 8spd trans new for Ford or was it in their other vehicles?
It’s notI'd wager that the transmission is different in the 4k vs non-4k trucks.
Same transmission with different gearing and a "large" transmission cooler.It’s not
They’re the same
Everything in the industry is about the money. Saving 10-15 cents, or less, when the unit count is in the hundreds or thousands can add up to a lot of money. Something designed with 8 fasteners can end up using only 4 and will save millions over the production run.I guess its still about the money.
You aren't wrong. A $20 k truck is going to be built around the most economical components to manufacture. The trans isn't wrong for the truck, it's the right choice. Keeps costs down and lets ford meet it's price goal while meeting performance requirements.Why the 8f35?
This truck started as the least expensive one available.
So I’m sure the cost has to come into play.
I’m not faulting them. i’m only sharing my thoughts.
Interesting you mention hunting for gears - mine doesn't do that at least not that I notice. Could be driving style? It would be interesting to see how the CVT would function with the EB. My limited experience with cvt's is fairly limited but also from 15 years ago. This one is supposed to be pretty good.Yep cost. And I don't like it. I would so much rather have the eCVT in my EB and I never thought I would say that. But I'm also part of the crowd on this forum that has noticed odd shifting and constant gear hunting. It drives me crazy. If there is one thing I can't stand in a vehicle it's a crappy transmission. I wish I could test drive some Mavericks on a lot around me but there are never any and I'd have to drive half a day just to find a used one to see if it's any different. Honestly, even with the features removed on the '24's I'm still weighing the pro's and cons of placing an order for a Tremor just for that reason alone. I'll test drive it and decide within the first 10 minutes of that drive if it's a noticeable difference in shifting. Still on the fence though, but the transmission drives me crazy and the way it shifts when coming to a stop actually makes me have to almost tap the brakes instead of a constant motion and it's borderline dangerous in the winter weather where I live.
You actually couldn't have the eCVT on a non hybrid vehicle, part of the CVT itself is the electric motor. You could only pair a traditional CVT with an ecoboost in which case I would rather take my chances with a traditional automatic like the 8F35Yep cost. And I don't like it. I would so much rather have the eCVT in my EB and I never thought I would say that. But I'm also part of the crowd on this forum that has noticed odd shifting and constant gear hunting. It drives me crazy. If there is one thing I can't stand in a vehicle it's a crappy transmission. I wish I could test drive some Mavericks on a lot around me but there are never any and I'd have to drive half a day just to find a used one to see if it's any different. Honestly, even with the features removed on the '24's I'm still weighing the pro's and cons of placing an order for a Tremor just for that reason alone. I'll test drive it and decide within the first 10 minutes of that drive if it's a noticeable difference in shifting. Still on the fence though, but the transmission drives me crazy and the way it shifts when coming to a stop actually makes me have to almost tap the brakes instead of a constant motion and it's borderline dangerous in the winter weather where I live.
Yep same. It's funny you mention this because I had a Subaru with a CVT and hated it, so I was skeptical going into the Hybrid Escape but ended up loving it's eCVT.You actually couldn't have the eCVT on a non hybrid vehicle, part of the CVT itself is the electric motor. You could only pair a traditional CVT with an ecoboost in which case I would rather take my chances with a traditional automatic like the 8F35
It feels more like my driving style has changed to cater to the low speed awkwardness of the transmission. My Tacoma was the opposite and the highway speeds were the ones that would annoy folks in the final gears. A tune really brought that truck to life especially after the lift. I had to retune to accommodate the new setup but it's so common with the Tacoma's is basically plug and play numbers. Shifting after the tune was never an issue on the highways. If the cost for a custom tune on the Maverick wasn't so expensive I'd give one a shot. Everything now days is tuned so much for the economy driving - which is fine, but I'd gladly sacrifice .5MPG for a better tune. Odd thing is, the tune on the Tacoma actually increased MPG slightly both with the stock setup and the lift.Interesting you mention hunting for gears - mine doesn't do that at least not that I notice. Could be driving style? It would be interesting to see how the CVT would function with the EB. My limited experience with cvt's is fairly limited but also from 15 years ago. This one is supposed to be pretty good.
One thing that does annoy me is the sensation of hard shifting at slow speeds. I do a lot of short distance stop and go driving and when I'm accelerating slowly at low speeds I often feel a clunk seemingly as it shifts. It might be the trans or perhaps the transfer case. Or maybe even something to do with the turbo cutting in or out? Once it gets up over 30 it's fine and on highways it's great but the slow, low speed stuff is annoying AF.
Very true but not completely, there the balance between money and customer satisfaction/needs. Poor reliability is acceptable for Ford because they know it will sell. If it didn't completely sell, they'd have to bump up reliability a bit.Everything in the industry is about the money. Saving 10-15 cents, or less, when the unit count is in the hundreds or thousands can add up to a lot of money. Something designed with 8 fasteners can end up using only 4 and will save millions over the production run.
The 8F35 spec'd could have some different internal parts, such as different friction material on the clutches, different thrust handling using bearings instead of bushings, etc.
They will provide adequate power handling capacity to cover the 9xth percentile of use that will likely work without problems for double the warranty period. Or some mix of percent/months and miles. To do more would likely increase the cost per unit and thus the MSRP.
I think I prefer a less complicated version rather than a BMW or Mercedes or Audi that is unaffordable once past the warranty period given the less complicated is easier and less expensive to repair.
It is all a balance between final cost and capabilities. Every design choice has a tradeoff, and as a customer you just hope they made good decisions. I would not have one of the brands metioned, and actually think FoMoCo does a decent job of meeting the design goals. I think their F-150 product is better than the other 2 brands, and that the Japanese brands in one case are leaving the market due to not selling, and in the other trading somewhat on their previous reputation.
We shall see...
It appears the 8F57 transmission is only for high torque V6 engines, such as the 2.7L V6 EcoBoost. That engine pushes out a little less than 100hp more than the 2.0L Ecoboost found in the Maverick, as well as about 100lb more torque.
It is likely overkill for the Maverick, an unnecessary waste of weight and cost.
